Plex is using "Offline Mode"
Plex on 1 of 4 Roku devices in my home is showing “Offline Mode”. The other 3 Rokus are running Plex normally. All the Rokus are connected to the same network and the same Plex server.
The Roku is a Roku Premiere. “Check Network” on the Roku shows it is connected.
I can use Plex in Offline Mode if I set “Allow Insecure Connections” to “On Same Network”.
How do I get Plex back online?
Same issue here, 1 Roku in the house is stuck this way for me. Let me know if you find a fix.
What model is your Roku that is doing the same thing as mine?
I think there is something about blocked traffic at the firewall but don’t understand why only one Plex client it impacted.
It was a 42" Onn Roku TV. Uninstalling and reinstalling Plex fixed it. The other Roku TV in my house was not having any issues.
if you don’t want to try reinstalling, ( or if that doesn’t work), can you grab the roku logs?
Reinstalling didn’t work, and now I have 3 rokus with the same problem. It seems to be something about the new Roku Home Screen update.
I might also have to do with my attempt to block home screen roku ads. Roku isn’t as happy as it used to be. However, I don’t understand why that would impact Plex unless Plex is using the Roku OS to verify internet connections.
Logs PMed to you BigWheel.
Welp…looks like I am part of the club. We have plex on two rokus. One acted up and a restart fixed it. The other would not. It would not allow a switch to profile and the profile it was on says ofline.
Do you have Pi-Hole or some other Roku domain blocker running?
I’m running pfblockerng and also a blacklist. If I disable pfblockerng, the Roku starts running better and Plex goes back online.
Can confirm this is the case for me. Running a pihole and 4 roku tvs all of which say they’re in offline mode, which started about 3 days ago. If I bypass my pihole all is well again.
far as I can tell it’s linked to Roku not being able to talk the it’s scribe url as all devices will fail internet connectivity too tests (but they work fine).
so FU Roku. I will not disable ad blocking for you to profit on devices I paid for.
scribe.logs.roku.com is a domain associated with Roku devices, primarily used for logging and tracking purposes. It is known for being a source of frequent connection attempts by Roku devices, which can be blocked for privacy reasons.”
Interestingly, so far my two Rokus that are connected by ethernet (instead of WiFi) suffered the same problems but after disabling the blockers, updating the Rokus, and then reenabling the blockers, those two Rokus and Plex have been fine.
I’m fine with Roku throwing a fit, but I don’t understand why Plex is showing offline. Another app on the same Rokus having problems, is able to stream content from outside my network. So, why is Plex showing offline?
I wonder if someone changed the url/ip that Plex uses to check connectivity, maybe to a Roku url
I see this in the Plex Roku logs. It appears Plex is just looking for plex.tv urls, and none of them are blocked from my ethernet connected PC. Going to try a wifi one right now…EDIT: Wifi connected PCs can reach the domains no problem.:
“tv.plex”: {
“isOnline”: false,
“lastChecked”: 1769455654,
“retryCount”: 8,
“status”: “offline”
“tv.plex.luma”: {
“isOnline”: false,
“retryCount”: 8,
“status”: “offline”
“tv.plex.provider.discover”: {
“isOnline”: false,
“retryCount”: 9,
“status”: “offline”
1/26/2026 14:27:34.589 [xxxxxxxxxxxxxxxxxxxxx] WARN (GeneralTask) [122683552] 185ms Request Failed! -60:SSL certificate problem: certificate is not yet valid GET https://clients.plex.tv/api/v2/user/privacy (json) (1ms preflight [1+0])
1/26/2026 14:27:34.590 [xxxxxxxxxxxxxxxxx] WARN (GeneralTask) [Metrics] Permissions failed to update
I wonder if the app references the TV state then. My downstairs TV is saying not connected but everything is working fine. But lex in offline mode again ofc
Yes, that seems to be the case even though the logs appears to say otherwise. I’m hoping @BigWheel can shed more light on the subject when he has some time after the long weekend to look at the logs I sent.
Offline means it cannot reach the plex.tv endpoints it needs. Logs show a certificate error that seems to be the cause of it.
is it just the scribe.logs.roku.com that you are blocking?
Not by a long shot, but these have been used in blocking for years without problems until now (some of them are repeats, I know, but it used to work perfectly):
analytics.plex.tv
ads.roku.com
amarillo.logs.roku.com
amoeba-plus.web.roku.com
amoeba.web.roku.com
assets.sr.roku.com
austin.logs.roku.com
bryan.logs.roku.com
camden.logs.roku.com
captive.roku.com
configsvc.cs.roku.com
cooper.logs.roku.com
customer-feedbacks.web.roku.com
digdug-g2.logs.roku.com
digdug.logs.roku.com
display.ravm.tv
esp.logs.roku.com
giga.logs.roku.com
gilbert.logs.roku.com
griffin.logs.roku.com
hereford.logs.roku.com
i.ads.roku.com
identity-dev.ads.roku.com
identity.ads.roku.com
keysvc.cs.roku.com
lagrange.logs.roku.com
lat-services.api.data.roku.com
liberty.logs.roku.com
littlefield.logs.roku.com
logs.roku.com
longview.logs.roku.com
longview.sb.roku.com
midland.logs.roku.com
mobile.logs.roku.com
navigation.sr.roku.com
p.ads.roku.com
paolo.logs.roku.com
prod.mobile.roku.com
raps-perf.ravm.tv
raps.ravm.tv
ravm.tv
richmond.logs.roku.com
rokutime.com
rollingwood.logs.roku.com
rxr.ravm.tv
samples.voice.cti.roku.com
sugarland.logs.roku.com
tis.cti.roku.com
traces.sr.roku.com
track.sr.roku.com
tyler.logs.roku.com
victoria.logs.roku.com
windsor.logs.roku.com
wwwimg.roku.com
Plus, pfblockerng is pulling for a few constantly updated sources online for other ad blocking.
I’m not blocking any of the plex domains that are listed in the Roku logs, and I have confirmed they are reachable via a browser. I don’t know why the logs show their connection attempts timeout.
Could just be DNS or NTP issues.
Not sure why you are getting SSL error yet.
So, my Roku tv (Hisense) got an update and this issue has gone away. Random and I can’t see why it would be related unless the Plex app got an update too but version number is the same
This sounds quite positive. I haven’t yet had a chance to investigate on the Rokus in my house that are having problems, but will let you know.
What version of the Roku OS do you current have?
I’m on 15.2.4 build 3455.
I’m still seeing issues.
