Plex Link Not Working
I’ve successfully set up my plex media server on my PC and loaded media onto it. I then installed the Plex app from the Google store on my Android TV. When prompted with the code to enter on plex.tv/link it always gives me the error that the “code not found or expired”
I’ve tried this several times, restarted both the TV and the server to no avail. Any help appreciated.
You have to be quick. The code is only valid for very few minutes.
Are you using a right-to-left language setting on either the TV or your web browser? If so, try reversing the code during input.
You sir, win the golden nugget. right-to-left language indeed and putting in the code reversed did the trick. Thanks!
