Plex linking the same file twice
For some reason my Plex has randomly linked the file twice for the same file path:
Although the file length is correct:
Screen Shot 2019-12-26 at 12.43.39 PM
Plex sees it as twice the length:
It appears as if its seeing it as two parts, but its not a two part file. and the file doesn’t exist twice either.
Ive done a full scan and even a partial scan but it still appears to be seeing this files like that
Plex Media Server Logs_2019-12-26_10-55-46.zip (4.5 MB)
Have a look at the naming style guide:
I found that this happens with you have more then one thing doing a scan at the same time. If you have something like Sonarr starting a scan do not have automatic scans turned on in Plex, they will both scan at the same time and add items twice.
