Plex Live-TV Channel Filtering Missing Channels
I’ve been using my HDHomerun with Plex and xTeVe (so I can re-order and filter out the channel amp as I needed). For the most part works great, but I’m having an odd issue with the channel filtering.
I have several channels that show up in the grid and configuration properly and are otherwise completely usable, but I cannot search for the channels when I try to apply a filter in the “Browse” section. When I goto “LiveTV & DVR” -> “Browse” -> Click on the “All” dropdown and try to filter by “Channel”, some channels are missing despite them being in the grid and in the LiveTV management section for the PVR. Any way around this issue? The channels appear to be configured correctly with all the right information and otherwise can be played back, just it is missing from the browse.
Missing search in “Browse”
Channel shows up correctly in grid
Using Plex docker version 1.20.5.3600, this is the same when I try to access LiveTV on Android, Chromecast, or Web latest app versions.
Found the problem, channel names and brackets in them “(”, once these were removed they showed up properly
