Plex Live TV not working with HDHomeRun CONNECT
Server Version#: 1.23.1.4571
Player Version#: 1.31.1.2262-74fdc6b7
Tuner Make/Model: HDHomeRun CONNECT
Guide/Lineup name:
Using XMLTV?:
Channel number/Name: 21.1
Error when clicking on channel in tv guide popup: “Playback Error” “Source is unavailable”
Settings: http://127.0.0.1:32400/web/index.html#!/settings/server/baf8c9bab6c25e7fe978f666d9a8a4eb9e30eaa3/manage/dvr
Tuner Devices
HDHomeRun CONNECT
Tuner status
Channels
(103)
IP address
http://192.168.1.104:80
Live playbqck works fine using Windows HDHomeRun App
Logs:
May 26, 2021 18:18:59.716 [26148] INFO - [Web] [MDE] Starting analysis of 1080 (mpegts, mpeg2video, ac3, 4, main)
May 26, 2021 18:18:59.716 [26148] INFO - [Web] [MDE] Analyzing direct play
May 26, 2021 18:18:59.716 [26148] ERROR - [Web] [MDE] Direct play failed; option is disabled
May 26, 2021 18:18:59.716 [26148] INFO - [Web] [MDE] Cannot direct play: allowDirectPlay
May 26, 2021 18:18:59.716 [26148] INFO - [Web] [MDE] Analyzing video direct stream
May 26, 2021 18:18:59.734 [26148] INFO - [Web] [MDE] Analyzing audio direct stream
May 26, 2021 18:18:59.734 [26148] INFO - [Web] [MDE] Analyzing subtitles
May 26, 2021 18:18:59.734 [26148] INFO - [Web] [MDE] Subtitle codec: eia_608
May 26, 2021 18:18:59.735 [26148] INFO - [Web] [MDE] Burn level: never
May 26, 2021 18:18:59.735 [26148] INFO - [Web] [MDE] Analyzing playability
May 26, 2021 18:18:59.735 [26148] ERROR - [Web] [MDE] Unable to determine effective quality; re-analyze the media if possible
May 26, 2021 18:18:59.735 [26148] INFO - [Web] [MDE] Finished analysis of: 1080 (mpegts, mpeg2video, ac3, 4, main) {
“canPlay”: true,
“canDirectPlay”: false,
“canDirectStreamVideo”: true,
“canDirectStreamAudio”: true,
“useSoftSubtitles”: false,
“videoResolution”: 1080
May 26, 2021 18:18:59.736 [26148] INFO - [Web] [PDE] Player decision: {
“playerType”: “html”,
“protocol”: “http”,
May 26, 2021 18:18:59.737 [26148] INFO - [Web] [Transcoder] Video (start) options: {
“hasMDE”: 1,
“path”: “/livetv/sessions/72e5fa4f-cd3f-4cd4-b596-8492abc7b3ac”,
“mediaIndex”: 0,
“partIndex”: 0,
“protocol”: “http”,
“fastSeek”: 1,
“directPlay”: 0,
“directStream”: 1,
“subtitleSize”: 75,
“audioBoost”: 100,
“location”: “lan”,
“addDebugOverlay”: 0,
“autoAdjustQuality”: 0,
“directStreamAudio”: 1,
“advancedSubtitles”: “text”,
“X-Plex-Session-Identifier”: “hmton0o0lw69nqgzg66n8vzq”,
“session”: “dnaz5vt5y9j2erpghbxjwtqg”,
“subtitles”: “auto”,
“copyts”: 0,
“X-Plex-Chunked”: 1,
“X-Plex-Incomplete-Segments”: 1
May 26, 2021 18:18:59.738 [26148] INFO - [Web] [Transcoder] Video (decision) options: {
“hasMDE”: 1,
“mediaIndex”: 0,
“partIndex”: 0,
“protocol”: “http”,
“fastSeek”: 1,
“directPlay”: 0,
“directStream”: 1,
“subtitleSize”: 75,
“audioBoost”: 100,
“location”: “lan”,
“copyts”: 0,
May 26, 2021 18:19:00.923 [26148] INFO - [Web] [Player] Timeline, {
“ratingKey”: “23562”,
“key”: “/livetv/sessions/72e5fa4f-cd3f-4cd4-b596-8492abc7b3ac”,
“playbackTime”: 0,
“state”: “error”,
“hasMDE”: 1,
“airingID”: “5316”,
“time”: 0,
“duration”: 3600000
May 26, 2021 18:19:00.923 [26148] ERROR - [Web] Did not move header “accept” to query string. This can result in an unnecessary OPTIONS preflight request.
May 26, 2021 18:19:00.923 [26148] INFO - [Web] [Metrics] Updating session last interaction time
May 26, 2021 18:19:00.923 [26148] ERROR - [Web] The provided value ‘undefined’ is not a valid enum value of type MediaSessionPlaybackState.
May 26, 2021 18:19:00.950 [26148] ERROR - [Web] The provided value ‘undefined’ is not a valid enum value of type MediaSessionPlaybackState.
May 26, 2021 18:19:00.950 [26148] INFO - [Web] [Metrics] Updating session last interaction time
Solved.
Needed to uncheck " Disable video stream transcoding " in Settings → Transcoder
