Recently I noticed my plex server wouldn’t connect. I solved a problem of running out of space on my server that seemed unrelated. After I restarted the comp plex had to reclaim the server. After that I also updated to the newest version. Things seemed fine, but live TV was gone. When I went to settings it just hangs with the “loading” rotating circle. If I enter my HDHomeRun connect duo’s ip address nothing on the screen change besides the fact that I can now click continue. After that it looks to go through the normal setup procedure until I get to the end. It says something like you can now view live TV under manage and we are downloading the guide. When I go back to the home page though nothing has changed and live tv is still missing. When I go back to settings the live TV section just shows the first “Set up live TV” page as if nothing happened. Would really appreciate some help here. No idea what changed and the world cup is happening
Can anyone help?
I have a similar issue with Android. Works fine in roku and web, but I get the “Set up live TV” message on the android client. It worked for a short time…I didn’t change anything.
