I had this set up previously, and it was working, but had to reinstall Windows & Plex. Since then, I can’t get the ‘Live TV’ option to appear despite completing setup.
So, if I go through the process:
Home > Settings > Server > Live TV & DVR > Set Up Plex DVR
Issue #1 - The HDHomeRun Quattro never detects.
I opt fo enter the address manually, hit ‘Connect’ and then ‘Continue’.
I see the list of channels detected by the HDHomeRun. I can (and have) hit 'Scan Chanels" and get the same results back. It is set for ‘Antenna’ and ‘United States’. Continue…
I provide my zip code. Continue.
It locates the guide and appears to successfully load it. It displays the 50-some channels I can detect. Continue.
Setup Complete!
You can now find your Guide and Recordings in the sidebar under “Live TV”. While we’re grabbing the guide data, you can start browsing; it will update automatically as we download what’s on.
View Guide is never NOT greyed-out. My only option (after waiting as long as 2 hours) is to click ‘Close’. After closing, I’m returned to the Live TV & DVR screen and ‘Live TV’ never shows up on the main page menu.
