Plex login Customize option
A request to the plex team . Is there any possibility to hid the email ID . its long and need to scroll a lot . If the username alone is shown it will be awesome.
It should be fine for plex home/pass holder . But home user’s finding it annoying at times.
Also the android app keeps logging out when phone switches off but that also if had a option not to lock out when phone is lock.
Hope this possible in feature request.
Like this?
yeah how do i enforce for home user’s . it their account i cant keep changing.
Oh yeah. You can’t. They control it. They have the same option to change it. I guess if you ask nicely enough your friends will change it. Or you can be a d%$k and tell them to change it to re-gain access to server.
