Server Version#: 4.87.2
Player Version#: 4.29.2
Hi all, is there a way to have PMP automatically select the 7.1 audio track when I play a movie? it always seems to select the 5.1 track for some reason.
thanks
Plex selects the first audio track that matches your language selections.
If you manually select a different audio track, Plex should remember that selection the next time you play the same movie/episode.
There is no way to change that behavior.
You can use tools such as MKVToolNix to re-order the audio tracks in a media file.
