Player Version#: 2.33.1.979-c4087ea7
Plex Media Player does not render correctly on my MS Surface Go. The PMP app occupies approx 3/4 of the screen and sits up in the top left.
The Surface has been taken out of S mode, is running Windows 10 Pro and the PMP app was downloaded from the Plex website.
Any suggestions please?
Thanks D2K
That looks like the windows is just moved too far up and left. Not sure how to do it with a touch screen, but with a mouse and keyboard you can right click on the icon in the task bar select move, then use the keys to move the window back into view.
Actually, that worked - thanks for the reminder about right click and move.
Odd though that it should be in that position after a clean install.
Thanks again.
D2K
