Server Version#:QNAP TS251+
Player Version#: 1.14.1.5488
Plex has been working a treat for 18 months. In last 24 hours every time I try to edit my music metadata (artists, collections etc.) the Media Player (whether stand alone app or in the browser) freezes after a few minutes. I have to kill the page/app and re open. Often the NAS Home page also freezes.
Very annoying, especially as I’ve got a huge task of editing ahead.
Using MacBook Pro Mojave 10.14.2
I’ve emptied cache of Chrome and restarted the NAS
Please verify DEBUG logging is enabled and VERBOSE logging is disabled.
Capture it again
Restart it.
Wait 60 seconds after restart then Download Logs
Attach the ZIP file.
Hi Chuck,
The Plex log was before restart.
The Plex debug was after I restarted, waited 60 seconds and downloaded the log. I enabled debug from the web client menu on the left side of the window.
Google blocked me sending a folder to you because they had js and css files.
Don’t know if that means I’ve still got the wrong info for you. But I’ve sent you the folder via WETRANSFER
Nate Rabe
Simply stated: You threw too much at it to digest all at once. The J1900 CPU is only 2000 Passmarks of performance. You need an i7-class machine to power through such a library.
There is an alternative.
Cancel the scanning.
Remove the library section you attempted to add
Begin subdividing your media into blocks of 5000-10000 items
Now recreate the new library, referencing the first block of 5-10,000 items
Allow this to complete
Edit the library section and add the top level folder for the next block of 5000-10000
PMS will be completely OK with this as there is no limit to the number of folders you can add.
Allow it to complete
Optimize the database
Repeat, adding the next block of files, until done
Make one final Optimize Database to ensure everything is at top efficiency
If I structure my music library with multiple folders of 5-10k tracks each (for example) will that limit my ability to view the entire library and listen to any track from any folder from the main ‘home’ screen.Or will I only be able to access, play and view the contents of one sub folder at a time? I make a lot of mixtapes and playlists and like the access to my entire collection in one place that a single library provides.
It doesn’t matter how many places the files are actually in. Plex will present you with the unified view of the library just as it would as if you had indexed it from much higher up the directory tree.
Because of how I backup media to external HDDs, I have the movie library broken into 2 parent shares and the TV library broken into 3.
