Hello, I installed successfully Plex-Media-Server in my gentoo (stable release).
I’m trying to initiate the daemon ‘/etc/init.d/plex-media-server restart’ but the process dropped after 2-3 seconds.
I got the below error:
May 23, 2019 22:49:09.987 [0x7f74a7b57700] INFO - Plex Media Server v1.13.2.5154-fd05be322 - ubuntu PC x86_64 - build: linux-ubuntu-x86_64 ubuntu - GMT 03:00
May 23, 2019 22:49:09.988 [0x7f74a7b57700] INFO - Linux version: 4.19.37-Ryzen7 (#1 SMP Sun May 5 21:44:24 EEST 2019), language: en-US
May 23, 2019 22:49:09.988 [0x7f74a7b57700] INFO - Processor AMD Ryzen 7 1700 Eight-Core Processor
May 23, 2019 22:49:09.988 [0x7f74a7b57700] INFO - ./Plex Media Server
May 23, 2019 22:49:09.987 [0x7f74a93d1840] DEBUG - BPQ: [Idle] -> [Starting]
May 23, 2019 22:49:09.988 [0x7f74a93d1840] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.13.0, threadsafe=1
May 23, 2019 22:49:09.990 [0x7f74a93d1840] INFO - SQLITE3:0x10, 283, recovered 1289 frames from WAL file /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
May 23, 2019 22:49:10.039 [0x7f74a93d1840] DEBUG - Running migrations.
May 23, 2019 22:49:10.041 [0x7f74a93d1840] DEBUG - ChangestampAllocator: initialized to 0
May 23, 2019 22:49:10.041 [0x7f74a93d1840] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.13.0, threadsafe=1
May 23, 2019 22:49:10.042 [0x7f74a93d1840] INFO - SQLITE3:0x10, 283, recovered 1289 frames from WAL file /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db-wal
May 23, 2019 22:49:10.047 [0x7f74a93d1840] DEBUG - Running migrations.
May 23, 2019 22:49:10.056 [0x7f74a93d1840] DEBUG - HttpServer: Listening on port 32400 with queue of 128 connections.
May 23, 2019 22:49:10.056 [0x7f74a93d1840] ERROR - HttpServer: Error binding acceptor: Cannot assign requested address
May 23, 2019 22:49:10.056 [0x7f74a93d1840] ERROR - Error: Unable to set up server: listen: Cannot assign requested address (N5boost16exception_detail10clone_implINS0_19error_info_injectorINS_6system12system_errorEEEEE)
gentoo /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Logs #
I have already tried to disable IPv6 in Preferences.xml without any luck.
Note that I don’t use the port 3400 in any other service.
gentoo ~ # netstat -patune | grep 32400
gentoo ~ #
I have noticed that if I add OldestPreviousVersion=“legacy” to Preferences.xml, the deamon is remaining alive but I still not be able to connect in localhost:32400/web in order to configure plex.
Any ideas?
thank you in advance.
Server Version#: 1.13.2-r1
Player Version#: Firefox Quantum 68.0.2
OS: GNU/Linux Gentoo stable release 2019
Kernel: gentoo-4.19.66
CPU: AMD Ryzen 7 1700 Eight-Core Processor
