[Plex Media Server] Forum Preview for Music Metadata
  1. Confirmed <Mood> tags now match the older agent.
  2. Fix match with mbid- is working for artists, but not for albums.
Other things from your list that I tested.
  • Creating new music libraries: working as expected.
  • Refreshing existing libraries: I have not tried refreshing an existing library.
  • Scanning: working as expected.
  • Matching: working as expected.
  • Artwork: Artist and album artwork from Plex Music is working as expected. I do not use local or embedded artwork.
  • Artist bios: working as expected.
  • Album reviews & ratings: working as expected.
  • Popular tracks: working as expected.
  • Lyrics: Automatic lyrics from online metadata is working as expected. I do not use local lyric files.
  • Concerts: I can’t find any artists in my library that have upcoming concerts.
  • Music videos: Local inline videos for both artist and track music videos are working as expected. ā€œGlobal music video pathā€ is working as expected.
  • Local metadata: I do not use local metadata.
  • Genres: Automatic genres from Plex Music is working as expected. I do not use embedded genre tags.
  • Add to Library: I don’t have a TIDAL subscription.
Confirmed I also saw the two known issues.
  1. Album artwork was set to the artist, but I think this was partially caused by #2 crashing.
  2. Tried to scan in new files and PMS crashed. Restarting the PMS showed the files were scanned in, but the albums had the artist artwork. Clicking refresh metadata caused PMS to crash again. Loudness analysis setting was set to ā€œas a scheduled taskā€. Changing loudness analysis to ā€œneverā€ allowed me to successfully refresh the metadata without crashing.
Do you have a sample or can you test this on your end?
This seems to work correctly on my end.
You don’t by any chance still have logs for this?
Actually, I think the not-first-artwork issue is a problem with the Plex Music Scanner or Plex Music agents, so it is still there. I started the beta on a different computer, scanning in a few files. With the Plex Music Scanner I can still get the second artwork instead of the first. Also, with the Plex Music (agent), I can get an artwork that is just based on the artist name and not the album, which is likely the problem with this last.fm service. (This artwork I can only see under ā€œRecently Added Musicā€, see next paragraph).
Anyway, a new library is created with the beta, but the page for this new library is not available. I see it on the left hand side with an attention mark, clicking on it doesn’t bring up the library. If I go to Home, I see that items were scanned in under Recently Added Music.
While I have your attention, I am wondering whether I can request a new feature for adding libraries: It would help me a lot if there were a user-specific setting under Advanced that you can just check once, and anytime you add a new library the scanner would have the same setting. As it is now, I need to choose, check and uncheck items up to 9 times each time, which gets cumbersome if you have a lot of libraries (I have about 40). I am not interested at all in any lyrics, or popularity, or upcoming concerts, or any such info. All I want is to use my local metadata and my embedded artwork. (I know there is somewhere a request new feature place, but things are hard to find in your fora).
ub
Just noticed. I can see and click on the new libraries with the app on the iPhone. But not on the computer in the browser.
I am using MacOs High Sierra 10.13.6 with Safari browser.
Thanks @drzoidberg33. It’s great to know it can’t be reproduced with the new code.
After your comment, I tested a bit more (with the regular PMS, not the new code) and found a few details related to this bug:
  • It seems to work correctly with a global music videos folder (as instructed here).
  • The bug seems to happen specifically with inline videos. When the videos are alongside the music files, it’s impossible to remove an item from the Extras row once it has been added, no matter what.
I sent you the logs in a PM.
I can confirm that inline video files do get removed.
Here is a test video I added.
I deleted the video file and refreshed the artist metadata. It briefly shows the video being removed with the trash can icon, then it automatically disappears after the metadata refresh is complete.
This is now part of the public beta.
