Plex media server on synology having issues with remote play
There was no DSM update not for a few months.
When you uninstall the package, you lose nothing.
I store the package (software) in one area.
I store your server instance (everything about your media and server) in the Plex share (on DSM 5 & 6)
When you uninstall, I only remove the software.
When it re-installs, it looks for an existing “Plex” shared folder.
If it finds one, it uses it without further investigation.
It will only create new if it doesn’t find one. If it does create, it creates on the same volume PMS (the software) is installed on.
I uninstalled PMS then installed the one available on DSM then let it prompt me to update did the update and Remote playback seems a tad better it buffers quicker now.
If you want another log let me know.
please attach it.
I am starting to suspect local network issues but in the absence of more data, I can’t be definitive.
There is one other way to test. Use the mobile device’s web browser for the playback. Let’s see if it’s the app or not. Maybe we can eliminate that as one of the variables.
Attached new log, I have not changed anything network wise. this issue started about 2-3 days ago.
Plex Media Server Logs_2021-02-28_20-56-38.zip (2.2 MB)
You may see a few playbacks. seems users are trying to watch stuff. some successfully and others not able to. I am able to start playback, but it doesn’t get far on my remote laptop.
Thank you for those different playback attempts. They helped me see what was going on at the next layer down.
  1. Audio convert only, Video = Copy
Feb 28, 2021 20:49:03.513 [0x7fa78dcd7700] DEBUG - Audio Stream: 289482, Subtitle Stream: -1
Feb 28, 2021 20:49:03.514 [0x7fa78dfc5700] DEBUG - [Transcode] TPU: hardware transcoding: final decoder: , final encoder:
Feb 28, 2021 20:49:03.515 [0x7fa78dcd7700] DEBUG - We're going to try to auto-select an audio stream for account 1.
Feb 28, 2021 20:49:03.515 [0x7fa78dcd7700] DEBUG - Selecting best audio stream for part ID 139029 (autoselect: 1 language: en)
Feb 28, 2021 20:49:03.515 [0x7fa78dcd7700] DEBUG - Audio Stream: 289484, Subtitle Stream: -1
Feb 28, 2021 20:49:03.516 [0x7fa78dfc5700] DEBUG - [Transcode/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/volume1/Plex/Library/Application\ Support/Plex\ Media\ Server/Codecs/367b3d4-3673-linux-x86_64/' X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxa' '/volume1/@appstore/Plex Media Server/Plex Transcoder' '-codec:0' 'h264' '-noaccurate_seek' '-analyzeduration' '20000000' '-probesize' '20000000' '-i' '/volume2/Plex Animated TV/Animated TV/Overlord/Season 3/[Golumpa] Overlord S3 - 12 (Overlord III) [FuniDub 720p x264 AAC] [9F53D2CA].mkv' '-map' '0:0' '-codec:0' 'copy' '-map' '0:1' '-metadata:s:1' 'language=eng' '-codec:1' 'copy' '-f' 'dash' '-seg_duration' '5' '-init_seg_name' 'init-stream$RepresentationID$.m4s' '-media_seg_name' 'chunk-stream$RepresentationID$-$Number%05d$.m4s' '-window_size' '5' '-delete_removed' 'false' '-skip_to_segment' '1' '-time_delta' '0.0625' '-manifest_name' 'http://127.0.0.1:32400/video/:/transcode/session/4h401u3ctqb54ob0tvoi359m/21cc3483-84dd-4cd0-8133-a1ddb0c78d78/manifest?X-Plex-Http-Pipeline=infinite' '-avoid_negative_ts' 'disabled' '-map_metadata' '-1' '-map_chapters' '-1' 'dash' '-start_at_zero' '-copyts' '-vsync' 'cfr' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/4h401u3ctqb54ob0tvoi359m/21cc3483-84dd-4cd0-8133-a1ddb0c78d78/progress'
2: Audio convert only , Video = Copy
Feb 28, 2021 20:54:55.198 [0x7fa78ffff700] DEBUG - Request: [12.36.186.130:60387 (WAN)] GET /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F49172&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=wan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=wgleqihllna8d73e7yv05z75&subtitles=burn&Accept-Language=en (29 live) TLS GZIP Signed-in Token (Destayeen)
Feb 28, 2021 20:54:55.198 [0x7fa78ffff700] DEBUG - [Transcode] Found session GUID of wgleqihllna8d73e7yv05z75 in session start.
Feb 28, 2021 20:54:55.199 [0x7fa78ffff700] DEBUG - [Transcode] TranscodeUniversalRequest: using augmented profile Firefox
Feb 28, 2021 20:54:55.199 [0x7fa78ffff700] DEBUG - [Transcode] Downloading document http://127.0.0.1:32400/library/metadata/49172?checkFiles=1&includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=s0c7knb04s7gd5az3v5ozrg8
Feb 28, 2021 20:54:55.199 [0x7fa78ffff700] DEBUG - [Transcode] Auth: authenticated user 1 as Destayeen
Feb 28, 2021 20:54:55.205 [0x7fa78ffff700] DEBUG - [Transcode] We're going to try to auto-select an audio stream for account 1.
Feb 28, 2021 20:54:55.205 [0x7fa78ffff700] DEBUG - [Transcode] Selecting best audio stream for part ID 122327 (autoselect: 1 language: en)
Feb 28, 2021 20:54:55.205 [0x7fa78ffff700] DEBUG - [Transcode] Audio Stream: 262879, Subtitle Stream: -1
Feb 28, 2021 20:54:55.206 [0x7fa78ffff700] DEBUG - [Transcode] Found session GUID of wgleqihllna8d73e7yv05z75 in session start.
Feb 28, 2021 20:54:55.207 [0x7fa78ffff700] DEBUG - [Transcode] Cleaning directory for session wgleqihllna8d73e7yv05z75 ()
Feb 28, 2021 20:54:55.207 [0x7fa78ffff700] DEBUG - [Transcode] Starting a transcode session wgleqihllna8d73e7yv05z75 at offset -1.0 (state=3)
Feb 28, 2021 20:54:55.208 [0x7fa78ffff700] DEBUG - [Transcode] TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Feb 28, 2021 20:54:55.208 [0x7fa78ffff700] DEBUG - [Transcode] [Universal] Using local file path instead of URL: /volume1/Plex TV/TV Shows/Game of Thrones/Season 5/Game Of Thrones S05e06.mkv
Feb 28, 2021 20:54:55.208 [0x7fa78ffff700] DEBUG - [Transcode] TPU: hardware transcoding: final decoder: , final encoder:
Feb 28, 2021 20:54:55.209 [0x7fa78ffff700] DEBUG - [Transcode/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/volume1/Plex/Library/Application\ Support/Plex\ Media\ Server/Codecs/367b3d4-3673-linux-x86_64/' X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxa' '/volume1/@appstore/Plex Media Server/Plex Transcoder' '-codec:0' 'h264' '-noaccurate_seek' '-analyzeduration' '20000000' '-probesize' '20000000' '-i' '/volume1/Plex TV/TV Shows/Game of Thrones/Season 5/Game Of Thrones S05e06.mkv' '-map' '0:0' '-codec:0' 'copy' '-map' '0:1' '-metadata:s:1' 'language=eng' '-codec:1' 'copy' '-f' 'dash' '-seg_duration' '5' '-init_seg_name' 'init-stream$RepresentationID$.m4s' '-media_seg_name' 'chunk-stream$RepresentationID$-$Number%05d$.m4s' '-window_size' '5' '-delete_removed' 'false' '-skip_to_segment' '1' '-time_delta' '0.0625' '-manifest_name' 'http://127.0.0.1:32400/video/:/transcode/session/wgleqihllna8d73e7yv05z75/a60926a1-5d22-41d7-b137-093dfc787ed4/manifest?X-Plex-Http-Pipeline=infinite' '-avoid_negative_ts' 'disabled' '-map_metadata' '-1' '-map_chapters' '-1' 'dash' '-start_at_zero' '-copyts' '-vsync' 'cfr' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/wgleqihllna8d73e7yv05z75/a60926a1-5d22-41d7-b137-093dfc787ed4/progress'
Feb 28, 2021 20:54:55.209 [0x7fa78ffff700] DEBUG - [Transcode/JobRunner] Jobs: Starting child process with pid 23501
3: Full Transcode: HW video enabled.
Feb 28, 2021 20:55:04.301 [0x7fa794567700] DEBUG - [Transcode] [Universal] Using local file path instead of URL: /volume3/Movies/Movies/Jiu.Jitsu.2020.1080p.WEB-DL.DD5.1.H264-FGT.mkv
Feb 28, 2021 20:55:04.302 [0x7fa794567700] DEBUG - [Transcode] Codecs: hardware transcoding: testing API vaapi
Feb 28, 2021 20:55:04.303 [0x7fa794567700] DEBUG - [Transcode] [FFMPEG] - Format 0x32315659 -> yuv420p.
Feb 28, 2021 20:55:04.303 [0x7fa794567700] DEBUG - [Transcode] [FFMPEG] - Format 0x30323449 -> yuv420p.
Feb 28, 2021 20:55:04.303 [0x7fa794567700] DEBUG - [Transcode] [FFMPEG] - Format 0x3231564e -> nv12.
Feb 28, 2021 20:55:04.303 [0x7fa794567700] DEBUG - [Transcode] [FFMPEG] - Format 0x32595559 -> yuyv422.
Feb 28, 2021 20:55:04.303 [0x7fa794567700] DEBUG - [Transcode] [FFMPEG] - Format 0x59565955 -> uyvy422.
Feb 28, 2021 20:55:04.303 [0x7fa794567700] DEBUG - [Transcode] [FFMPEG] - Format 0x48323234 -> yuv422p.
Feb 28, 2021 20:55:04.303 [0x7fa794567700] DEBUG - [Transcode] [FFMPEG] - Format 0x58424752 -> rgb0.
Feb 28, 2021 20:55:04.303 [0x7fa794567700] DEBUG - [Transcode] [FFMPEG] - Format 0x58524742 -> bgr0.
Feb 28, 2021 20:55:04.303 [0x7fa794567700] DEBUG - [Transcode] [FFMPEG] - Format 0x30313050 -> p010le.
Feb 28, 2021 20:55:04.303 [0x7fa794567700] DEBUG - [Transcode] [FFMPEG] - Created surface 0x4000000.
Feb 28, 2021 20:55:04.303 [0x7fa794567700] DEBUG - [Transcode] [FFMPEG] - Direct mapping possible.
Feb 28, 2021 20:55:04.304 [0x7fa794567700] DEBUG - [Transcode] TPU: hardware transcoding: final decoder: vaapi, final encoder: vaapi
Feb 28, 2021 20:55:04.304 [0x7fa794567700] DEBUG - [Transcode/JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/volume1/Plex/Library/Application\ Support/Plex\ Media\ Server/Codecs/367b3d4-3673-linux-x86_64/' LIBVA_DRIVERS_PATH='/volume1/@appstore/Plex Media Server/lib/dri' X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxa' '/volume1/@appstore/Plex Media Server/Plex Transcoder' '-codec:0' 'h264' '-hwaccel:0' 'vaapi' '-hwaccel_fallback_threshold:0'
This has every indication of network issue between the server & player.
Is this server in an environment where there are some additional infrastructure IT equipment ? (something between the server and the actual ISP )
I have the NAS Attached to An ASUS RT-AX58U and there is An arris modem no ISP rented hardware.
I did notice this error message in the console on plex
SSDP: Error parsing device schema for http://192.168.50.1:1990/WFADevice.xml
That IP is the Router.
I cannot explain – but I’ve seen it in several cases – There is something about these “AI Mesh” wifi devices which drives PMS nuts.
I think it has something to do with their automatic channel provisioning (backhaul).
In a nutshell, it gets it wrong. It is trying to provision for Full Duplex operation on two different frequencies simultaneously and doesn’t understand how PMS needs it.
Normal WiFi is simple half-duplex (one transmits at a time). With good signal and enough channel with (40 Mhz or 80 Mhz), it will scream along.
yeah I would say that would be the newest addition to the network is another AI mesh router but Its very odd that the NAS has issue with the wifi even though its connected with a wire.
Also Remote playback seems to at least start now. it has a bit of a delay now it used to not. but at least it works sorta. some users report no playback still but not sure if there is anything I can do about that.
If I disable Local network discovery (GDM) will this prevent that error from showing up?
and or will this effect my local playback at all?
