Plex Media Server regularly suddenly unavailable
This is the script cron runs at the intervals you set to check if PMS is running.
If it’s crashed, it restart PMS
So this is a workaround in the event that I cannot find the corrupt media file.
@sjkiss
Yes, this is a workaround until you find the bad file
I am just returning to this because the system crashed again. Do I save this in an .sh script somewhere? I think I have to make it executable and then add a line in the crontab file to run this script. Have I got that right?
I’m attaching the server logs from the most recent crash. I can’t find a similar line that indicates when it happened. It most likely happened early on October 15th, or late on October 14th.
Can you help me repeat that process ? I am figuring out how I might be able to find the corrupted file. I have some ideas. @ChuckPa
Plex Media Server Logs_2025-10-16_09-45-54.zip (3.6 MB)
