i have been running plex media server on a pi3 with no issues for almost a year.it stopped working from one day to the next and i have scoured everything but cant get it working. When i check the status using a PuTTY terminal from a remote computer i get the following:
pi@raspberrypi:~ sudo service plexmediaserver status
● plexmediaserver.service - Plex Media Server for Linux
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled)
Active: failed (Result: start-limit) since Mon 2018-03-26 23:40:28 AEDT; 25s ago
Process: 4062 ExecStart=/bin/sh -c LD_LIBRARY_PATH=/usr/lib/plexmediaserver "/usr/lib/plexmediaserver/Plex Media Server" (code=exited, status=134)
Process: 4058 ExecStartPre=/bin/sh -c /usr/bin/test -d "{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p “${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” (code=exited, status=0/SUCCESS)
Main PID: 4062 (code=exited, status=134)
Mar 26 23:40:23 raspberrypi systemd[1]: Unit plexmediaserver.service entered…
Mar 26 23:40:28 raspberrypi systemd[1]: plexmediaserver.service holdoff time…
Mar 26 23:40:28 raspberrypi systemd[1]: Stopping Plex Media Server for Linux…
Mar 26 23:40:28 raspberrypi systemd[1]: Starting Plex Media Server for Linux…
Mar 26 23:40:28 raspberrypi systemd[1]: plexmediaserver.service start reques…
Mar 26 23:40:28 raspberrypi systemd[1]: Failed to start Plex Media Server fo…
Mar 26 23:40:28 raspberrypi systemd[1]: Unit plexmediaserver.service entered…
Hint: Some lines were ellipsized, use -l to show in full.
any help appreciated… want command to use to get around this message “Hint: Some lines were ellipsized, use -l to show in full.”
Please post the output of journalctl -u plexmediaserver.
Hope this is what you were after, Thanks for your help
Mar 27 22:30:04 raspberrypi systemd[1]: Starting Plex Media Server for Linux…
Mar 27 22:30:04 raspberrypi systemd[1]: Started Plex Media Server for Linux.
Mar 27 22:30:06 raspberrypi sh[31740]: terminate called after throwing an instance of ‘std::runtime_error’
Mar 27 22:30:06 raspberrypi sh[31740]: what(): Codecs: Initialize: ‘boost::filesystem::create_directory: No space left on device: “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/7814ac9-1285-linux-annapurnatrans-arm7”’
Mar 27 22:30:06 raspberrypi sh[31740]: ****** PLEX MEDIA SERVER CRASHED, CRASH REPORT WRITTEN: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Crash Reports/1.12.1.4885-1046ba85f/PLEX MEDIA SERVER/2133d2b4-99fe-2f25-15a1b34e-6f659e40.dmp
Mar 27 22:30:06 raspberrypi sh[31740]: Aborted
Mar 27 22:30:06 raspberrypi systemd[1]: plexmediaserver.service: main process exited, code=exited, status=134/n/a
Mar 27 22:30:06 raspberrypi systemd[1]: Unit plexmediaserver.service entered failed state.
Mar 27 22:30:11 raspberrypi systemd[1]: plexmediaserver.service holdoff time over, scheduling restart.
Mar 27 22:30:11 raspberrypi systemd[1]: Stopping Plex Media Server for Linux…
Mar 27 22:30:11 raspberrypi systemd[1]: Starting Plex Media Server for Linux…
Mar 27 22:30:11 raspberrypi systemd[1]: Started Plex Media Server for Linux.
Mar 27 22:30:12 raspberrypi sh[803]: terminate called after throwing an instance of ‘std::runtime_error’
Mar 27 22:30:12 raspberrypi sh[803]: what(): Codecs: Initialize: ‘boost::filesystem::create_directory: No space left on device: “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/7814ac9-1285-linux-annapurnatrans-arm7”’
Mar 27 22:30:12 raspberrypi sh[803]: ****** PLEX MEDIA SERVER CRASHED, CRASH REPORT WRITTEN: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Crash Reports/1.12.1.4885-1046ba85f/PLEX MEDIA SERVER/744cab4a-5f73-67af-4b4ead84-3c7d8579.dmp
Mar 27 22:30:12 raspberrypi sh[803]: Aborted
Mar 27 22:30:12 raspberrypi systemd[1]: plexmediaserver.service: main process exited, code=exited, status=134/n/a
Mar 27 22:30:12 raspberrypi systemd[1]: Unit plexmediaserver.service entered failed state.
Mar 27 22:30:17 raspberrypi systemd[1]: plexmediaserver.service holdoff time over, scheduling restart.
Mar 27 22:30:17 raspberrypi systemd[1]: Stopping Plex Media Server for Linux…
Mar 27 22:30:17 raspberrypi systemd[1]: Starting Plex Media Server for Linux…
Mar 27 22:30:17 raspberrypi systemd[1]: Started Plex Media Server for Linux.
Mar 27 22:30:19 raspberrypi sh[2277]: terminate called after throwing an instance of ‘std::runtime_error’
Mar 27 22:30:19 raspberrypi sh[2277]: what(): Codecs: Initialize: ‘boost::filesystem::create_directory: No space left on device: “/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/7814ac9-1285-linux-annapurnatrans-arm7”’
Mar 27 22:30:19 raspberrypi sh[2277]: ****** PLEX MEDIA SERVER CRASHED, CRASH REPORT WRITTEN: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Craash Reports/1.12.1.4885-1046ba85f/PLEX MEDIA SERVER/3549a602-f4b7-105a-29fd14fc-01459a59.dmp
Mar 27 22:30:19 raspberrypi sh[2277]: Aborted
Mar 27 22:30:19 raspberrypi systemd[1]: plexmediaserver.service: main process exited, code=exited, status=134/n/a
Mar 27 22:30:19 raspberrypi systemd[1]: Unit plexmediaserver.service entered failed state.
Mar 27 22:30:24 raspberrypi systemd[1]: plexmediaserver.service holdoff time over, scheduling restart.
Mar 27 22:30:24 raspberrypi systemd[1]: Stopping Plex Media Server for Linux…
Mar 27 22:30:24 raspberrypi systemd[1]: Starting Plex Media Server for Linux…
Mar 27 22:30:24 raspberrypi systemd[1]: plexmediaserver.service start request repeated too quickly, refusing to start.
Mar 27 22:30:24 raspberrypi systemd[1]: Failed to start Plex Media Server for Linux.
Mar 27 22:30:24 raspberrypi systemd[1]: Unit plexmediaserver.service entered failed state.
yeah, i noticed that, anyway to remove unused files to increase space, or just look for a bigger SD card?
First try the below tips and then get a larger SD card. To check the free space in Linux just use df -h.
(1) Did you resize your partition after initial OS installation with raspi-config to fill the SD card?
https://elinux.org/RPi_Resize_Flash_Partitions
(2) You can disable and remove the video preview and chapter thumbnails in Plex to reduce the meta data size significantly.
https://support.plex.tv/articles/202197528-video-preview-thumbnails/
thanks i’ll give that a go. Thanks heaps for your help
You could also use a USB drive to hold the Plex metadata. An ext4 partition is recommended.
Using noobs, so raspi-config doesn’t work
ended up making disk image and moving to a 32GB card that I had which was verified to work with NOOBS installation.
then used this guide to make sure the whole SD card was being used:
https://dracoy.com/2016/06/26/expanding-partition-on-sd-card-for-raspberry-pi-with-noobs-pre-installed/
works a treat now and only 46% of space used, i’ll keep an eye on it and if filling quickly i’ll disable metadata.
thanks for putting me on the right path, much appreciated!!
