Plex Media Server will not run
Server Version#:1.42.2.10156-f737b826c-x86_64
Player Version#:1.112.0.359-0d79a49f
I can install Plex Media Server without issues but it will not run. Instead I get a window that says;
Plex Media Server.exe - Entry Point Not Found
The procedure entry point curl_url_get could not be located in the dynamic link library C:\Program Files\Plex\Plex Media Server\Plex Media Server.exe.
Can anyone give me some guidance on what to do please?
Ensure that you are using a supported Windows version. Windows 11 or Windows 10 on a PC with x86 compatible CPU.
Download the Plex Server installer again https://www.plex.tv/media-server-downloads/?cat=computer&plat=windows#plex-media-server
Thanks for the quick response.
I am running on Windows 10 and my system type ‘X64-based PC’ is compatible.
I have downloaded and installed (and re-installed) 3 the PlexMediaServer-1.42.2.10156-f737b826c-x86_64.exe file. Rebooting the PC after each Plex Media Server failure.
I still get the same error :frowning:
I can provide the log file if that will pinpoint the problem.
Is this a new PC, or one which already had Plex server installed before?
Now sorted thanks. After installation the server would not run, however task manager showed it was running and I was able to view media on my TV from the PC. :slight_smile:
