Plex Media Server 0.9.17.3 is now available for Plex Pass members.
NEW
Get concert information from Songkick service. (#4664 )
(Sync, Media Optimizer) Unthrottle background transcodes when all streaming transcodes are throttled. (#4621 )
Synology Alpine package has now been merged into the normal ARMv7 package.
FIXES
(Sync) Time out if upload to cloud storage provider stalls. (#4772 )
(Network) Respect X-Forwarded-For headers when determining remote address. (#4682 )
(Security) Corrected some edge cases parsing the allowed networks preference. (#730 )
(Security) Donât re-enable server publishing on sign-in, if it was disabled. (#4118 )
(Security) Refresh TLS certificate at most once per process. (#4765 )
(Transcoder) Run background transcodes at normal priority when preference to prefer streaming transcodes is disabled. (#4625 )
(Transcoder) Unthrottle background transcodes when streaming transcodes throttle. (#1901 )
(Transcoder) Donât store files in /Plex directory (#4718 )
(Media Analysis) Incorrect duration in certain rare cases. (#4703 )
(Media Optimizer) Defer in-progress directory creation until transcode begins. (#4709 )
(Metadata) Missing metadata with non-English locales. (#4712 )
(Metadata) Failures getting metadata from TMDb metadata. (#4738 , #4746 )
(Linux) Invalid locale crashes with certain startup scripts. (#4717 )
(NAS) Crashes on some Synology devices. (#4737 )
After splitting two merged home movies, editing one would affect the other. (#4524 )
Note: Synology users that are using the Alpine package need to switch to the ARMv7 package
Plex Media Server 1.0.0 is now available for everyone.
Blog Post: https://www.plex.tv/blog/long-winding-road-v1-0/
Please Note: Windows Vista, Windows Server 2008 and OS X 10.6/10.7 as well as certain older NAS devices are no longer supported in PMS 1.0
NEW
Update Plex Web to 2.7.0 .
(Chromecast) Use opus instead of mp3 when transcoding music. (#4805 )
(Sync) Changed Sync database format. Downgrading to older Plex Media Server builds may cause Sync problems. (#3959 )
FIXES:
(Sync) Synced content wouldnât show up on iOS in some rare cases. See https://forums.plex.tv/discussion/175998/planned-features-known-issues/ (#3959 )
(Media Analysis) Crashes analyzing certain .wtv files. (#4789 )
(Network) Update plex.tv server information when port mapping fails. (#4758 )
(Metadata) Speed up album refreshes in some cases when using Last.fm agent.
(Transcoder) Playback failures skipping to near end of video. (#4803 )
(Transcoder) Rare crashes with unreliable internet connections. (#4803 )
To ensure weâre efficiently allocating development resources across all platforms, maintenance and support for versions of Plex Media Server prior to 1.0 will be discontinued. This will help Plex focus efforts not only on bringing exciting new functionality to life, but also on enhanced stability as we move forward.
Plex Media Server 1.0.1 is now available for Plex Pass members.
NEW
Update Plex Web to 2.7.4 .
Updated Media Flags bundle.
(Preferences) Advanced preference to run the scanner at low priority (intended for low-powered devices). (#4845 )
(Metadata) Rename Freebase Agent to Plex Movie Agent.
(Metadata) Plex Movie Agent combines the best possible metadata from multiple sources (IMDb, The Movie Database, and Rotten Tomatoes).
(Metadata) Added preferences to Plex Movie Agent and TheTVDB Agent to control metadata source of rating, cast info, and summary.
(Metadata) Allow TheTVDB agent to use The Movie DBâs HD episode images, so you can have the best of both worlds.
(Metadata) Upgrade to TheTVDB API v2.
FIXES
(Transcoder) Playback failures playing subtitles on iOS with a Windows server. (#4828 )
(Transcoder) Crashes with unreliable internet connections. (#4827 )
(Transcoder) Playback issues with AAC audio containing more than six channels on Windows (#4830 , #4843 )
(Transcoder) Crashes in certain error cases. (#4881 )
(Transcoder) Errors transcoding source audio with negative timestamps on Windows. (#4833 )
(Transcoder) Errors transcoding subtitles. (#4862 )
(Transcoder) Errors decoding MSMPEG4v3 video on certain platforms. (#4919 )
(Transcoder) Server hangs while transcoding in certain rare cases. (#4943 )
(Media Analysis) Scanner could hang with 100% CPU usage when analyzing videos with invalid packets. (#4821 )
(Metadata) Remove broken Google search for matching movies and TV shows.
(Now Playing) Channel content wasnât showing up in Now Playing. (#4893 )
(Security) Refresh TLS certificate after signing out multiple times. (#4817 )
(Network) Respect X-Forwarded-For headers sent from local or loopback addresses. (#4682 )
(Network) Crashes unpublishing the server in certain rare cases. (#4885 )
(Framework) Noisy âHTTPErrorâ object has no attribute âreadâ errors in logs. (#4449 )
(FreeBSD) Update checks werenât working correctly. (#4844 )
(OS X) In some cases, lyrics would not display (#4872 )
(Web) Playback failures when media has unselected subtitles. (#4939 )
(PHT) Compatibility issues with version 1.0.0 (#4831 )
Chapters from ChapterDB might not load under some circumstances. (#4814 )
Crashes in deep media analysis. (#4886 )
Plex Media Server 1.0.2 is now available for Plex Pass members.
NEW
Save track offsets in music libraries that have opted in. (#3370 )
FIXES
(OS X) Startup failures on some older versions of MacOS. (#4969 )
(Windows) DLNA server process might not have a firewall exemption. (#4136 )
(Claiming) Better error message if server claiming fails (#4907 )
(Linux) Fix migration script for users with custom app data directories. (#4808 )
(Linux) Improve Fedora/Ubuntu SELinux support. (#4808 )
(Metadata) Issues fetching metadata for Pokémon TV series. (#4966 )
(Metadata) Handle multiple directors returned from TVDB. (#4960 )
(Metadata) Fetch localized titles correctly using Plex Movie Agent. (#4963 )
Plex Media Server 1.0.2 is now available for everyone.
See the previous notes for details.
Plex Media Server 1.0.3 is now available for everyone.
FIXES
Crash handling certain requests from PS4 clients. (#4984 )
(OS X) Donât prevent the display from going to sleep.
(Metadata) Issues obtaining data from TVDB, requiring server restart.
(Metadata) Fallback to English TVDB searches when searching with another language fails. (#4933 )
(Metadata) Tracks and disc numbers in premium music libraries could be affected by bad tag data. (#4437 )
Plex Media Server 1.1.0 is now available for Plex Pass members.
NEW:
Support videos in photo libraries. (#3928 )
Support uploading videos to photo libraries. (Android support is available now and other mobile apps are coming soon.) (#3522 )
(Web) Updated Plex Web to 2.7.8.
(Security) When server is signed in, clients must be signed in as well, even if they are on the LAN or on localhost. (#3819 )
(Preferences) New pref to enable/disable deep media analysis.
(Windows) Updating the server from Plex Web no longer requires user intervention. (#4136 )
FIXES:
(Sync) Items present in multiple synced playlists would only appear in the first synced playlist. (#4967 )
(Media Optimizer) Unexpected behavior when version jobs overlap to include the same videos. (#4840 )
(Media Optimizer) Reprocess item when original processing decided a media item was compatible, but the media item was deleted. (#4840 )
(Transcoder) Playback failures with pcm_dvd audio. (#4980 )
(Transcoder) Use faster AAC encoder on slower NAS systems. (#5058 )
(Media Analysis) Scanner hangs with early AAC files from iTunes. (#5041 )
(Media Analysis) Improve performance of deep media analysis. (#5068 )
(Media Analysis) Issues generating video preview thumbnails for certain HEVC videos on windows. (#5139 )
(Butler) Long-running Butler tasks could starve others from executing (#4873 )
(Chapters) Chapter thumbnail generation could fail repeatedly with invalid media. (#5043 )
(Metadata) Improve TVDB agent performance by not using TMDb information. (#5110 )
(Metadata) Changing title could overwrite sort title. (#3971 )
(Metadata) Fall back to release dates from TMDB when IMDB has no data. (#4978 )
(Metadata) Fall back to English-language fields when metadata is unavailable in desired language. (#5015 )
(Metadata) Show durations in minutes could be incorrectly interpreted as milliseconds (#5012 )
(Metadata) Handle empty movie release dates from TMDb. (#5096 )
(Photos) Photos might play back in wrong order. (#5035 )
(Windows) Install Media Feature Pack on Windows Anniversary Update N and KN (#5064 )
(Windows) Plex Relay process wasnât starting up in some configurations. (#5118 )
(OS X) Plex Relay executable wasnât correctly signed.
(OS X) Occasional crashes on some older versions of MacOS. (#5028 )
(Android) Improve H.264 limitations in profile. (#4930 )
(iOS) âGo to Showâ from episode context menu wasnât working. (#4811 )
(Xbox One) Improve reliability when proxying Plex Companion commands. (#4002 )
Improve localization of certain error messages. (#4587 )
Plex Media Server 1.1.1 is now available for Plex Pass members.
NEW:
(Web) Updated Plex Web to 2.7.10
(Security) âNetworks allowed without authâ preference now also works when server is signed in.
(Security) âNetworks allowed without authâ preference can be used with IP addresses, as well as netmask filters.
(Network) Browsers denied access to the serverâs root path are now redirected to Plex Web. (#5100 )
FIXES:
(Subtitles) Subtitle auto selection didnât quite match the specification. (#4565 )
(Relay) Issues starting relay on certain NAS devices. (#5126 )
(Metadata) Show theme music wasnât downloaded when using third party TVDB DVD order agent. (#5159 )
(Metadata) Occasional issues getting metadata from TVDB. (#5199 )
(Shows) Fixed viewing seasons with the unwatched filter enabled on older and third party clients. (#5182 )
(Thumbnails) Failures running scheduled task for thumbnail generation. (#5195 )
(Extras) Cloud trailers might not be downloaded on startup on faster systems. (#5188 )
(Channels) Only offer iTunes, iPhoto, and Aperture channel preferences on supported platforms. (#5157 )
(Windows) Disable iTunes channel by default. (#5157 )
(Windows) Issues loading Plex Web on IE11 (#5181 )
(OS X) Fix auto-update not working in some cases. (#5212 )
(Now Playing) Issues with play queues containing mixed photos and videos. (#5164 )
Some rare server crashes. (#4951 )
Plex Media Server 1.1.2 is now available for Plex Pass members.
FIXES:
(Security) Devices authorized with the ânetworks allowed without authâ preference were unable to render images and play media when the server was signed in.
(OS X) Fix issue with automatic updates. (Upgrades from 1.1.0 and 1.1.1 will require manual installation.)
Plex Media Server 1.1.3 is now available for everyone.
IMPORTANT: With the security changes in version 1.1.0, if your Plex Media Server is signed in to a plex.tv account, then all of the apps you use must also be signed-in. If you use older apps that cannot authenticate (e.g. LGâs MediaLink or SmartShare apps), you can add the IP address of the device to the following advanced preference: Settings > Server > Network > List of IP addresses and networks that are allowed without auth. (We strongly encourage apps to be signed in for improved security and enhanced functionality.)
NEW:
(Media Flags) Update bundle.
FIXES:
(NAS) Non-ASCII characters were being encoded to XML incorrectly on certain ARM devices. (#5255 )
(Android) Enforce h264 profile limitations correctly. (#5233 )
Plex Media Server 1.1.4 is now available for everyone.
NEW:
(Web) Updated Plex Web to 2.8.1.
(Nvidia Shield) Enable DLNA server. (#5013 )
(Security) Allow http requests using the serverâs machine name to authenticate using the ânetworks allowed without authâ preference. (#5270 )
Improved crash reporting infrastructure. (#4669 )
FIXES:
(LG) Connectivity problems when older LG MediaLink TVs connect to signed-in servers with whitelisted IP addresses. (#5271 )
(Ubuntu) Installation failures on certain VPS systems lacking /proc/1/comm. (#5300 )
(QNAP) Issues restarting PMS after unclean shutdown. (#5309 )
(Trailers) Plex Movie agent âUse red band (restricted audiences) trailers when availableâ preference was being ignored when downloading trailers. (#5298 )
Enabling network logging in clients could cause the server to hang. (#5277 )
Spurious âStreaming session doesnât existâ errors when playing synced content on certain clients. (#5264 )
Plex Media Server 1.2.1 is now available for Plex Pass members.
Blog Post: https://www.plex.tv/blog/mcstreamy-brain-take-world-two-easy-steps/
NEW
New Feature - Streaming Brain.
(Streaming Brain) Preference for limiting bandwidth on WAN uploads. Limits can be per-stream and total (Plex Pass only).
(Streaming Brain) Playback session termination reasons are sent to the client and displayed to the user. This may require an updated client.
(Streaming Brain) Removed âPrioritize streaming transcodesâ preference. Background transcodes such as Sync, Media Optimizer, and video preview thumbnail generation are always prioritized behind streaming transcodes, and will pause completely if the simultaneous transcode limit is reached.
(Streaming Brain) Removed âCloud Sync upload speed limitâ preference. Sync traffic automatically scales based on streaming WAN usage, and uses whatever bandwidth is left unused (Plex Pass only).
(Web) Updated Plex Web to 2.9.3. Plex Web is updated in PMS 1.2.2 Plex Pass release.
(Relay) Allow multiple connections from PMS to relay servers. (#4894 )
(Windows) Localize installer for Simplified Chinese and Traditional Chinese locales. (#5189 )
(Linux) QNAP x64 packages for the new QTS 4.3 64bit firmware.
FIXES:
(NVIDIA SHIELD) Relay was crashing on startup. (#5419 )
(Transcoder) Failures transcoding video files that lack a video stream. (#4503 )
(Transcoder) Stuttering video transcoding HE-AAC on macOS. (#5376 )
(Transcoder) Completed transcodes might continue to block static transcodes. (#5423 )
(Subtitles) Inconsistent automatic subtitle selection for media containing multiple embedded subtitles. (#5011 )
(On Deck) Handle specials and episodes without a known air date better in On Deck. (#4661 )
(Camera Upload) Fix a couple of edge case scenarios when resuming uploads. (#5152 ) (#5218 )
(Pub-Sub) Better load distribution selecting servers. (#4915 )
(Relay) Relay process might not be killed when the media server shuts down on certain Unix platforms. (#5173 )
(Butler) Issues deleting old files in cache directory.
(Media Analysis) Scanner crashes analyzing mp4 files lacking moov atoms. (#5373 )
(Media Analysis) Some 1080i media wasnât being recognized as being interlaced. (#5279 )
(Media Analysis) Crashes analyzing certain photos with malformed metadata tags. (#5461 )
(Metadata) Issues recognizing episodes of shows whose names contain multiple numeric digits. (#5377 )
(Search) Duplicate results from different libraries now indicate the library of origin. (#4949 )
(Search) Treat searches using a single non-ASCII character the same as a single ASCII character. (#5319 )
(Linux) Local Media Agent errors when paths/files contained non-ASCII characters. (#5470 )
(Linux) Fixed Readynas RN2xx build to work on ReadyNAS OS Firmware 6.6.0 (#5512 )
A number of user-reported server crashes. (#5042 ) (#5459 )
Plex Media Server 1.2.2 is now available for Plex Pass members.
FIXES:
(Web) Updated Plex Web 2.9.3, which was missing from the previous release
StSimm1
October 25, 2016, 10:02am
134
Plex Media Server 1.2.3 is now available for Plex Pass members.
NEW
(Web) Updated Plex Web to 2.10.5.
(Localization) Updated server translations.
FIXES:
(Network) Clients might incorrectly report a server as unclaimed or remote access as unavailable after network timeouts. (#4994 )
(Streaming Brain) In some cases the server could unexpectedly reserve any remaining bandwidth. (#5447 )
(Streaming Brain) Playback failures on Android. (#5537 #5589 )
(Streaming Brain) Issues starting transcode sessions with OpenPHT. (#5546 )
(Streaming Brain) Issues transcoding sidecar subtitles while Direct Playing a video. (#5540 )
(Scanner) Library section analysis wasnât always working. (#5536 )
(Scanner) Issues scanning TV series with numeric names. (#5547 )
(Camera Upload) Duplicate photos could be uploaded in some cases on case-sensitive filesystems. (#5509 )
(Camera Upload) Uploads were failing if the target library path didnât already exist. (#5553 )
(Music) Unplayable music videos might show up after refreshing certain albums. (#5559 )
(Metadata) Issues obtaining preview images from fanart.tv . (#5524 )
(Linux) Transcoder errors caused by an invalid locale configuration on certain systems. (#4717 )
(NAS) Crashes on ReadyNAS 6.6. (#5567 )
(NAS) Issues scanning when paths contained non-ASCII characters. (#5618 )
Plex Media Server 1.2.4 is now available for Plex Pass members.
NEW
(Web) Updated Plex Web to 2.10.7.
FIXES:
(PS4) Crash starting music playback from a PS4. (#5620 )
(Scanner) Issues handling non-ASCII characters in path names on certain platforms. (#5129 ) (#5231 )
(Linux) Crashes adding or removing libraries on some platforms. (#5615 )
(Linux) Donât override the default Python install on Centos/Fedora. (5651)
(OS X) Exclude *.photoslibrary from default photos library. (#4910 )
A number of user-reported server crashes. (#5598 ) (#5644 ) (#5647 )
Plex Media Server 1.2.5 is now available for everyone.
FIXES:
(Music) Issues scanning premium music libraries. (#5684 )
(Metadata) Issues obtaining preview images from fanart.tv . (#5665 )
Plex Media Server 1.2.6 is now available for everyone.
FIXES:
(TV) Issues playing transcoded music on the PlayStation 4 and other TV and Web apps. (#5703 )
Plex Media Server 1.2.7 is now available for everyone.
NEW:
(Web) Updated Plex Web to 2.10.10.
(Media Flags) Updated bundle.
FIXES:
Playback issues on Roku, iOS and other platforms. (#5715 )
Occasional server hangs during video playback. (#5505 ) (#5658 )
Plex Media Server 1.3.0 is now available for Plex Pass members.
NEW
(Web) Updated Plex Web to 2.11.0.
(Photos) Optional automatic tagging of photos in Photo libraries. (Requires a Plex Pass.)
(Photos) Massively improved performance of photo library scans.
(Music) Improve matching of local album art. (#5654 )
FIXES:
(Apple TV) Improve seeking behavior. (#5029 )
(Sync) Issues syncing photo sync items on folders with lots of subfolders. (#5284 )
(Sync) Occasional issues syncing from multiple sync clients. (#5767 )
(Sync) Errors syncing playlists inside folders. (#5780 )
(Transcoder) Boost audio using a rematrix adjustment, instead of simply increasing volume. (#4594 )
(Scanner) Music scanner fails to scan in files with replaygain_seratogain_gain. (#4352 )
(Scanner) Issues refreshing libraries when library locations contained trailing slashes. (#5396 )
(Scanner) Issues scanning certain Hawaii Five-O episodes.
(Scanner) Duplicate status alerts generated for Camera Uploads. (#5150 )
(Metadata) Adding an album to Various Artists was causing other albums to be refreshed. (#4418 )
(Metadata) Preserve user edited text fields when unmatching and rematching a media file. (#4999 )
(Video) Improve performance when direct streaming video on some TV apps. (#5532 )
(Music) The music library created during setup wasnât premium for Plex Pass users. (#5775 )
(Music) Support local per-track music videos, stored globally. (#5564 )
(Music) Replace âPopular New Music Videosâ hub with âRecently Added Music Videosâ. (#5564 )
(Relay) Cache host keys to improve relay startup performance. (#5516 )
(DLNA) Issues with TV show watched status on DLNA clients and LG Medialink. (#5609 )
(DLNA) Crash generating DIDL for videos with no video streams. (#5731 )
(Sharing) Issues with content rating restrictions containing diacritics and other non-ASCII characters. (#5565 )
(HTTP) Return 503 errors when server is overloaded. (#5530 )
(Search) Duplicate search results in certain cases. (#5657 )
(Safari) Downloads werenât resuming correctly. (#5548 )
(iTunes) Importing iTunes playlist from a non-default location wasnât working on Windows. (#5755 )
Artwork and images might not display in certain clients when the server wasnât signed in. (#5748 )
A number of user-reported server crashes. (#5465 ) (#5773 ) (#5788 ) (#5804 )
Plex Media Server 1.3.1 is now available for Plex Pass members.
NEW
(Web) Updated Plex Web to 2.12.3.
(Transcoder) Improved performance and stability.
(Transcoder) Use platform-provided fonts when burning subtitles on Windows and OS X. Reduces application package size.
(Media Analysis) Updated video and music media analysis to be more stable and consistent across platforms.
FIXES:
(Photos) Avoid occasional duplicate tagging of images during scan. (#5836 )
(Media Analysis) Deep analysis data was being erased under some circumstances. (#5898 )
(Windows) Crashes when running Resource Monitor. (#5832 )
(DLNA) Crashes browsing photos library sections. (#5874 )
(Relay) Relayed connections werenât always working with shared users. (#5869 )
(Linux) Issues with Premium Music on some Linux/NAS x86 platforms. (#5897 )
(Linux) Install issues on CentOS/Fedora/Ubuntu. (#5903 ) (#5905 )
(Scanner) Clean up show names obtained from file names.
A number of user-reported server crashes. (#5850 ) (#5871 ) (#5873 ) (#5855 )
