Plex works at 50%
Hi, i'm on windows XP
I did all the steps for the SSL
My problem is my ATV recognize my PLEX and load all the movies list and everything
but when i select a movie or anything else, it doesn't load and says trailers unavailable
Log :
11:54:36 PlexConnect: started: 11:54:36
11:54:36 PlexConnect: IP_self: 192.168.1.139
11:54:36 DNSServer: started: 11:54:36
11:54:36 DNSServer: ***
11:54:36 DNSServer: Starting up.
11:54:36 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.1.139
11:54:36 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
11:54:37 DNSServer: forward other to higher level DNS: 205.151.67.34
11:54:37 DNSServer: ***
11:54:37 WebServer: started: 11:54:37
11:54:37 WebServer: ***
11:54:37 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
11:54:37 WebServer: WebServer: Serving HTTPS on 0.0.0.0 port 443.
11:54:37 PlexGDM: ***
11:54:37 PlexGDM: looking up Plex Media Server
11:54:38 PlexGDM: servers discovered: 1
11:54:38 XMLConverter: PlexGDM - PMS: 192.168.1.139:32400
11:55:10 DNSServer: DNS request received!
11:55:10 DNSServer: Source: ('192.168.1.121', 49246)
11:55:10 DNSServer: Domain: p48-buy.itunes.apple.com.akadns.net
11:55:10 DNSServer: ***forward request
11:55:10 DNSServer: -> DNS response from higher level
11:55:12 DNSServer: DNS request received!
11:55:12 DNSServer: Source: ('192.168.1.121', 62498)
11:55:12 DNSServer: Domain: itunes.apple.com
11:55:12 DNSServer: ***forward request
11:55:12 DNSServer: -> DNS response from higher level
11:55:12 DNSServer: Source: ('192.168.1.121', 58878)
11:55:12 DNSServer: Domain: ax.init-cdn.itunes.apple.com.akadns.net
11:55:13 DNSServer: DNS request received!
11:55:13 DNSServer: Source: ('192.168.1.121', 53515)
11:55:13 DNSServer: Domain: trailers.apple.com
11:55:13 DNSServer: ***intercept request
11:55:13 DNSServer: -> DNS response: 192.168.1.139
11:55:14 WebServer: serving application.js
11:55:15 DNSServer: DNS request received!
11:55:15 DNSServer: Source: ('192.168.1.121', 51241)
11:55:15 DNSServer: Domain: atv.plexconnect
11:55:15 DNSServer: ***intercept request
11:55:15 DNSServer: -> DNS response: 192.168.1.139
11:55:15 WebServer: serving .xml: /PlexConnect.xml
11:55:15 ATVSettings: add section 007
11:55:16 WebServer: serving  C:\Documents and Settings\Jimmy\Bureau\PlexConnect-XML_templates\assets\js\utils.js
11:55:16 ATVLogger: loadItem: Library
11:55:16 WebServer: serving .xml: /library/sections
and my settings
[PlexConnect]
port_pms = 32400
enable_plexgdm = True
ip_dnsmaster = 8.8.8.8
ip_webserver = 0.0.0.0
loglevel = Normal
enable_dnsserver = True
ip_pms = 192.168.178.10
port_webserver = 80
logpath = .
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
certfile = ./assets/certificates/trailers.pem
port_ssl = 443
Have you tried restarting PMS? I would make sure you have the up-to-date public version of PMS (9.8.5) and deep scan your libraries. Also, what firmware is installed on the ATV?
im on 9.7.28 on pms and it says im on latest
i deep scanned my librairies and my aptv firmware is 5.1
OK, there is currently an issue with firmware 5.1 and Plexconnect. Baa would probably appreciate if you could set log level to high in the Plexconnect settings.cfg file, restart Plexconnect, try to play a movie and then attach the resulting Plexconnect.log file to a post in this thread. He wants to diagnose the problem. After you do that, you can upgrade to 5.3 to solve the problem, or wait until Baa sorts something out for 5.1.
10:20:15 PlexConnect: started: 10:20:15
10:20:15 PlexConnect: IP_self: 192.168.1.139
10:20:15 DNSServer: started: 10:20:15
10:20:15 DNSServer: ***
10:20:15 DNSServer: Starting up.
10:20:15 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.1.139
10:20:15 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
10:20:15 DNSServer: forward other to higher level DNS: 8.8.8.8
10:20:16 WebServer: started: 10:20:16
10:20:16 WebServer: ***
10:20:16 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
10:20:16 WebServer: WebServer: Serving HTTPS on 0.0.0.0 port 443.
10:20:16 PlexGDM: ***
10:20:16 PlexGDM: looking up Plex Media Server
10:20:17 PlexGDM: servers discovered: 1
10:20:17 XMLConverter: PlexGDM - PMS: 192.168.1.139:32400
10:20:54 DNSServer: DNS request received!
10:20:54 DNSServer: Source: ('192.168.1.121', 61275)
10:20:54 DNSServer: Domain: trailers.apple.com
10:20:54 DNSServer: ***intercept request
10:20:54 DNSServer: -> DNS response: 192.168.1.139
10:20:55 WebServer: serving application.js
10:20:56 DNSServer: DNS request received!
10:20:56 DNSServer: Source: ('192.168.1.121', 59153)
10:20:56 DNSServer: Domain: atv.plexconnect
10:20:56 DNSServer: ***intercept request
10:20:56 DNSServer: -> DNS response: 192.168.1.139
10:20:56 WebServer: serving .xml: /PlexConnect.xml
10:20:56 WebServer: serving  C:\Documents and Settings\Jimmy\Bureau\PlexConnect-XML_templates\assets\js\utils.js
10:20:56 ATVLogger: loadItem: Library
10:20:56 WebServer: serving .xml: /library/sections
10:20:58 ATVLogger: loadURL (override): http://atv.plexconnect/library/sections/1
10:20:58 WebServer: serving .xml: /library/sections/1
10:20:58 WebServer: serving  C:\Documents and Settings\Jimmy\Bureau\PlexConnect-XML_templates\assets\js\utils.js
10:20:58 WebServer: serving  C:\Documents and Settings\Jimmy\Bureau\PlexConnect-XML_templates\assets\js\updateXML.js
10:20:59 ATVLogger: 1
10:20:59 WebServer: serving .xml: /library/sections/1
10:21:00 WebServer: serving  C:\Documents and Settings\Jimmy\Bureau\PlexConnect-XML_templates\assets\js\utils.js
10:21:00 WebServer: serving  C:\Documents and Settings\Jimmy\Bureau\PlexConnect-XML_templates\assets\js\scrobble.js
10:21:00 WebServer: serving  C:\Documents and Settings\Jimmy\Bureau\PlexConnect-XML_templates\assets\js\updateXML.js
10:21:00 WebServer: serving  C:\Documents and Settings\Jimmy\Bureau\PlexConnect-XML_templates\assets\js\settings.js
10:21:02 ATVLogger: loadURL (override): http://atv.plexconnect/library/metadata/1288&PlexConnect=MoviePrePlay
10:21:02 WebServer: serving .xml: /library/metadata/1288
I wasn't sure if upgrading to 5.3 was a good thing... for the j/b or something else I have i just installed the new plex 9.8.5
Thanks for the normal log but could you set the log level to high in settings.cfg. Restart, and try to play something. Then attach the whole Plexconnect.log file to a post here. We need more info from the full log to solve it.
here it is, but i think i have some problem with the HIGH settings, ( I've restarted everything )
High - with capital "H" and lower level "igh".
i have some issues uploading the .txt file, so i'll copy code
( should i upgrade my ATV )
http://www.2shared.com/file/y9zMwQ2K/PlexConnect.html
Great log!
Looks like your PlexConnect is one complete mess :-D
"g_CommandCollection" errors everywhere. I find it hard to believe that this changes with iOS 5.3... But then, the update might affect http request timings.
Please do not update just yet - one workaround is to NOT use the PrePlayScreen, but directly press PLAY on the movie.
And a fix might not be far - please download PlexConnect from branch "SSL_process" and give it a try. It is not really nice coded (as in checks for every issue before running over it...) but it *should* solve the g_CommandCollection issue.
Thanks for debugging!
could you give me the link, i'm still noobish in this
It works if I push the play  button directly
here's the log when i press play
Link: https://github.com/iBaa/PlexConnect/tree/SSL_process
Direct Play - yes, thought so. "g_CommandCollection" errors messed up your file completely. Interestingly in the latest LOG there is not one of the errors...
Anyway, please do the testing with the newer branch - you don't want to miss out on the PrePlayScreen, do you?
New log with the new code
same problem
http://www.2shared.com/file/9fc4veRe/PlexConnect.html
