Hello All
I was hoping you may be able to help me with my problem. Please see below. I am running an ATV3 with Windows 7 and latest Plex Media Server installed. I installed Plexconnect with latest stable build and installed profiles to ATV3 and followed all directions. I have run Plex on my ATV3 just fine but something has happened where it will not load anymore. I have tried everything, reinstalled plexconnect, rest, restored and tried again fresh but still no help and I really can't figure out what is going on. It will load on the trailer icon and I can see the movie tabs and such but nothing from there just blank movie posters. Below is what I got from my CMD/Python script
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Windows\System32> cd \program files
C:\Program Files> cd plexconnect
C:\Program Files\PlexConnect>plexconnect.py
21:07:03 PlexConnect: ***
21:07:03 PlexConnect: PlexConnect
21:07:03 PlexConnect: Press CTRL-C to shut down.
21:07:03 Settings: add setting enable_plexgdm=True
21:07:03 Settings: add setting ip_pms=192.168.178.10
21:07:03 Settings: add setting port_pms=32400
21:07:03 Settings: add setting enable_dnsserver=True
21:07:03 Settings: add setting port_dnsserver=53
21:07:03 Settings: add setting ip_dnsmaster=8.8.8.8
21:07:03 Settings: add setting prevent_atv_update=True
21:07:03 Settings: add setting enable_plexconnect_autodetect=True
21:07:03 Settings: add setting ip_plexconnect=0.0.0.0
21:07:03 Settings: add setting hosttointercept=trailers.apple.com
21:07:03 Settings: add setting port_webserver=80
21:07:03 Settings: add setting enable_webserver_ssl=True
21:07:03 Settings: add setting port_ssl=443
21:07:03 Settings: add setting certfile=./assets/certificates/trailers.pem
21:07:03 Settings: add setting loglevel=Normal
21:07:03 Settings: add setting logpath=.
21:07:03 PlexConnect: started: 21:07:03
21:07:03 PlexConnect: Version: 0.3.1+
21:07:03 PlexConnect: Python: 2.7.6 (default, Nov 10 2013, 19:24:24) [MSC v.1500
64 bit (AMD64)]
21:07:03 PlexConnect: Host OS: win32
21:07:03 PlexConnect: IP_self: 192.168.1.2
21:07:03 DNSServer: started: 21:07:03
21:07:03 DNSServer: ***
21:07:03 DNSServer: DNSServer: Serving DNS on 192.168.1.2 port 53.
21:07:03 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.2
21:07:03 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld
.apple.com.edgesuite.net'] => 127.0.0.1
21:07:03 DNSServer: forward other to higher level DNS: 8.8.8.8
21:07:03 WebServer: started: 21:07:03
21:07:03 WebServer: ***
21:07:03 WebServer: WebServer: Serving HTTP on 192.168.1.2 port 80.
21:07:03 WebServer: Failed to access certificate: C:\Program Files\PlexConnect\a
ssets\certificates railers.pem
21:07:07 PlexConnect: Shutting down.
21:07:07 WebServer: Shutting down.
21:07:08 DNSServer: Shutting down.
21:07:08 PlexConnect: shutdown
21:07:42 PlexConnect: ***
21:07:42 PlexConnect: PlexConnect
21:07:42 PlexConnect: Press CTRL-C to shut down.
21:07:42 PlexConnect: started: 21:07:42
21:07:42 PlexConnect: Version: 0.3.1+
21:07:42 PlexConnect: Python: 2.7.6 (default, Nov 10 2013, 19:24:24) [MSC v.1500
64 bit (AMD64)]
21:07:42 PlexConnect: Host OS: win32
21:07:42 PlexConnect: IP_self: 192.168.1.2
21:07:42 DNSServer: started: 21:07:42
21:07:42 DNSServer: ***
21:07:42 DNSServer: DNSServer: Serving DNS on 192.168.1.2 port 53.
21:07:42 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.2
21:07:42 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld
21:07:42 DNSServer: forward other to higher level DNS: 8.8.8.8
21:07:42 WebServer: started: 21:07:42
21:07:42 WebServer: ***
21:07:42 WebServer: WebServer: Serving HTTP on 192.168.1.2 port 80.
21:07:42 WebServer: WebServer: Serving HTTPS on 192.168.1.2 port 443.
21:08:31 DNSServer: DNS request received!
21:08:31 DNSServer: Source: ('192.168.1.9', 63430)
21:08:31 DNSServer: Domain: api-global.netflix.com
21:08:31 DNSServer: ***forward request
21:08:31 DNSServer: -> DNS response from higher level
21:08:31 DNSServer: Source: ('192.168.1.9', 60598)
21:08:31 DNSServer: Domain: secure.netflix.com
21:08:32 DNSServer: DNS request received!
21:08:32 DNSServer: Source: ('192.168.1.9', 53223)
21:08:32 DNSServer: Domain: nmtracking.netflix.com
21:08:32 DNSServer: ***forward request
21:08:32 DNSServer: -> DNS response from higher level
21:08:44 DNSServer: DNS request received!
21:08:44 DNSServer: Source: ('192.168.1.9', 61940)
21:08:44 DNSServer: Domain: trailers.apple.com
21:08:44 DNSServer: ***intercept request
21:08:44 DNSServer: -> DNS response: 192.168.1.2
21:08:45 WebServer: serving /js/application.js
21:08:45 WebServer: serving .xml: /
21:08:45 ATVSettings: add section DY5KDDHXFF54
21:08:45 PlexAPI: ***
21:08:45 PlexAPI: looking up Plex Media Server
21:08:46 PlexAPI: GDM: Servers discovered: 1
21:08:46 PlexAPI: Servers (local+MyPlex): 1
21:08:46 WebServer: serving .xml: /PlexConnect.xml
21:08:46 WebServer: serving /js/utils.js
21:08:46 WebServer: serving .xml: /library/sections
21:08:46 WebServer: serving /js/sectionHoldSelect.js
21:08:47 WebServer: serving .xml: /library/sections/1/recentlyAdded
21:08:50 WebServer: serving .xml: /library/sections/1
21:08:50 WebServer: serving /js/utils.js
21:08:50 WebServer: serving /js/updateXML.js
21:08:56 WebServer: serving /js/utils.js
21:08:56 WebServer: serving /js/updateXML.js
21:08:59 WebServer: serving /js/settings.js
21:09:08 WebServer: serving .xml: /library/sections/1/director
21:09:29 WebServer: serving .xml: /library/sections/1/actor
21:10:08 DNSServer: DNS request received!
21:10:08 DNSServer: Source: ('192.168.1.9', 50705)
21:10:08 DNSServer: Domain: trailers.apple.com
21:10:08 DNSServer: ***intercept request
21:10:08 DNSServer: -> DNS response: 192.168.1.2
Exception happened during processing of request from ('192.168.1.9', 49226)
Traceback (most recent call last):
File "C:\Python27\lib\SocketServer.py", line 295, in _handle_request_noblock
self.process_request(request, client_address)
File "C:\Python27\lib\SocketServer.py", line 321, in process_request
self.finish_request(request, client_address)
File "C:\Python27\lib\SocketServer.py", line 334, in finish_request
self.RequestHandlerClass(request, client_address, self)
File "C:\Python27\lib\SocketServer.py", line 651, in __init__
self.finish()
File "C:\Python27\lib\SocketServer.py", line 710, in finish
self.wfile.close()
File "C:\Python27\lib\socket.py", line 279, in close
self.flush()
File "C:\Python27\lib\socket.py", line 303, in flush
self._sock.sendall(view[write_offset:write_offset+buffer_size])
error: [Errno 10054] An existing connection was forcibly closed by the remote ho
st
21:10:19 WebServer: serving .xml: /library/sections/1/director
Exception happened during processing of request from ('192.168.1.9', 49228)
self.finish()
self.wfile.close()
self.flush()
error: [Errno 10053] An established connection was aborted by the software in yo
ur host machine
21:10:44 PlexConnect: Shutting down.
21:10:45 WebServer: Shutting down.
21:10:48 DNSServer: Shutting down.
21:10:48 PlexConnect: shutdown
