Server Version#:
It says 4.63.0 on the “Plex Web—General” page on browser on server - I have no idea what that is, and searching web to find where to find “Server Version” and “Player Version” found nothing useful - you really need to change code to print these two out clearly on your web interface somewhere!
Problem:
Summary:
PLEX on Shield seems to play the Bluray version instead of the 4K version (or at least the audio tracks from Bluray version only) when both are on PLEX server.
Details:
I have direct, non-transcoded Bluray rips (MKV format) of my own Bluray movies collection stored on PC rack server - playing Direct Play to NVidia Shield 2017. Renamed to standard naming using Filebot before adding. These were all added to PLEX previously and worked fine.
I now buy 4K UltraHD Blurays to replace the older Bluray versions of movies in collection.
I also now rip these and add to PLEX in same way.
So I have TWO versions and resolutions of lots of movies now on server.
There is settings on PLEX on Shield to choose which version you want to play.
I recently noticed that it is not behaving correctly at all in terms of audio playback. It seems to get mixed up between the audio tracks somehow and only play the audio from the Bluray version, even though the video from the 4K version is playing (at least that is the version I told it to play!)
Reason I noticed this is that I was wondering why Dolby Atmos was not showing up as playing on my Denon receiver, and when I went to choose audio settings of the 4K movie playing, there was no option for True-HD 7.1, only DTS-HD 5.1 - ie only audio available to play was the tracks from the Bluray version. The Playback Info page also showed this.
I knew it must not be picking the correct version to play at all, so I went into PLEX server and deleted the Bluray version to test - and this fixed the problem - after this the 4K version played Dolby Atmos with no problem.
This same problem happened on multiple movies I tried… Guardians of the Galaxy, Matrix Trilogy, Annihilation, Blade Runner 2049, The Martian.
Note: it doesn’t always happen - I also have two Bluray+4K of “Star Wars- The Rise of Skywalker” on it, and it appears to play the 4K version correctly with Dolby Atmos track.
I know not many keep two versions, but still it does happen as you upgrade from DVD->Bluray->4K
I have lots of duplicates and now I have to go through server finding lower resolution versions and deleting them to get past this bug.
To recreate - buy Bluray + 4K version of Blade Runner 2049 - add to PLEX using Filebot renamer, try and play the 4K version in Dolby Atmos.
