MPV Shim for Plex
MPV Shim is a simple and lightweight Plex client, with support for Windows and Linux. Think of it as an open source Chromecast for Plex. You can cast almost anything from Plex and it will Direct Play. Subtitles are fully supported, and there are tools to manage them like no other Plex client.
Source Repository: https://github.com/iwalton3/plex-mpv-shim
Getting Started
If you are on Windows, simply download the binary. If you are using Linux or OSX, please see the Linux Installation or OSX Installation sections below.
To use the client, simply launch it and cast your media from another Plex application. The mobile and web applications are supported. You do not have to log in to the client or set it up in any other way.
If you want to use the web application to cast, you must either be on the same network as a Plex server (an empty one will work) or install the MPV Shim Local Connection user script.
The application runs with a notification icon by default. You can use this to view the application log, open the config folder, and open the application menu.
Advanced Features
Menu
To open the menu, press c on your computer or home within the Plex mobile apps.
The menu enables you to:
- Adjust video transcoding quality.
- Change the default transcoder settings.
- Change subtitles or audio, while knowing the track names.
- Change subtitles or audio for an entire series at once.
- Mark the media as unwatched and quit.
On your computer, use the arrow keys, enter, and escape to navigate. On your phone, use the arrow buttons, ok, back, and home to navigate. (The option for remote controls is shown next to the name of the client when you select it from the cast menu.)
Please also note that the on-screen controller for MPV (if available) cannot change the audio and subtitle track configurations for transcoded media. It also cannot load external subtitles. You must either use the menu or the application you casted from.
Keyboard Shortcuts
This program supports most of the keyboard shortcuts from MPV. The custom keyboard shortcuts are:
- < > to skip episodes
- q to close player
- w to mark watched and skip
- u to mark unwatched and quit
- c to open the menu
Here are the notable MPV keyboard shortcuts:
- space - Pause/Play
- left/right - Seek by 5 seconds
- up/down - Seek by 1 minute
- s - Take a screenshot
- S - Take a screenshot without subtitles
- f - Toggle fullscreen
- ,/. - Seek by individual frames
- [/] - Change video speed by 10%
- {/} - Change video speed by 50%
- backspace - Reset speed
- m - Mute
- d - Enable/disable deinterlace
- Ctrl+Shift+Left/Right - Adjust subtitle delay.
Configuration
The configuration file is located in different places depending on your platform. You can open the configuration folder using the systray icon. When you launch the program on Linux or OSX from the terminal, the location of the config file will be printed. The locations are:
- Windows -
%appdata%\plex-mpv-shim\conf.json - Linux -
~/.config/plex-mpv-shim/conf.json - Mac OSX -
Library/Application Support/plex-mpv-shim/conf.json - CygWin -
Transcoding
You can adjust the basic transcoder settings via the menu.
always_transcode- This will tell the client to always transcode, without asking. Default:false- This may be useful if you are using limited hardware that cannot handle advanced codecs.
- You may have some luck changing
client_profilein the configuration to a more restrictive one.
auto_transcode- This will ask the server to determine if transcoding is suggested. Default:true-
transcode_kbps- Transcode bandwidth to request. Default:2000 -
direct_limit- Also limit direct play totranscode_kbps. Default:false - Note that
direct_limitcannot be overriden without changingtranscode_kbps. - If
direct_limitis not set, the player assumes the server will set the limit.
adaptive_transcode- Tell the server to adjust the quality while streaming. Default:false
Shell Command Triggers
You can execute shell commands on media state using the config file:
media_ended_cmd- When all media has played. -
pre_media_cmd- Before the player displays. (Will wait for finish.) -
stop_cmd- After stopping the player. -
idle_cmd- After no activity foridle_cmd_delayseconds.
Subtitle Visual Settings
All of these settings apply to direct play and are adjustable through the controlling app. Note that some may not work depending on the subtitle codec. Subtitle position and color are not available for transcodes.
subtitle_size- The size of the subtitles, in percent. Default:100 -
subtitle_color- The color of the subtitles, in hex. Default:#FFFFFFFF -
subtitle_position- The position (top, bottom, middle). Default:bottom
External MPV
The client now supports using an external copy of MPV, including one that is running prior to starting the client. This may be useful if your distribution only provides MPV as a binary executable (instead of as a shared library), or to connect to MPV-based GUI players. Please note that SMPlayer exhibits strange behaviour when controlled in this manner. External MPV is currently the only working backend for media playback on OSX.
mpv_ext- Enable usage of the external player by default. Default:false- The external player may still be used by default if
libmpv1is not available.
mpv_ext_path- The path to thempvbinary to use. By default it uses the one in the PATH. Default:null- If you are using Windows, make sure to use two backslashes. Example:
C:\\path\\to\\mpv.exe
mpv_ext_ipc- The path to the socket to control MPV. Default:null- If unset, the socket is a randomly selected temp file.
- On Windows, this is just a name for the socket, not a path like on Linux.
mpv_ext_start- Start a managed copy of MPV with the client. Default:true- If not specified, the user must start MPV prior to launching the client.
- MPV must be launched with
--input-ipc-server=[value of mpv_ext_ipc].
Other Configuration Options
player_name- The name of the player that appears in the cast menu. Initially set from your hostname. -
http_port- The TCP port to listen on for Plex to control the player. Default:3000 -
enable_play_queue- Enable play queue support. Default:true- If you disable this, the application will queue media based on the series.
- This is a legacy feature. It is not regularly tested.
client_uuid- The identifier for the client. Set to a random value on first run. -
audio_ac3passthrough- Does not work. Currently only changes transcoder settings. Default:false -
audio_dtspassthrough- Does not work. Currently only changes transcoder settings. Default:false -
allow_http- Allow insecure Plex server connections. Default:false- This may be useful if you are using a Plex server offline or not signed in.
client_profile- The client profile for transcoding. Default:Plex Home Theater- It may be useful to change this on limited hardware.
- If you change this, it should be changed to a profile that supports
hlsstreaming.
sanitize_output- Prevent Plex tokens from being printed to the console. Default:true -
fullscreen- Fullscreen the player when starting playback. Default:true -
enable_gui- Enable the system tray icon and GUI features. Default:true -
media_key_seek- Use the media next/prev keys to seek instead of skip episodes. Default:false -
enable_osc- Enable the MPV on-screen controller. Default:true- It may be useful to disable this if you are using an external player that already provides a user interface.
log_decisions- Log the full playback URLs. Default:false -
mpv_log_level- Log level to use for mpv. Default:info- Options: fatal, error, warn, info, v, debug, trace
MPV Configuration
You can configure mpv directly using the mpv.conf and input.conf files. (It is in the same folder as conf.json.) This may be useful for customizing video upscaling, keyboard shortcuts, or controlling the application via the mpv IPC server.
Development
If you’d like to run the application without installing it, run ./run.py. The project is written entierly in Python 3. There are no closed-source components in this project. It is fully hackable.
The project is dependent on python-mpv, python-mpv-jsonipc, and requests. If you are using Windows and would like mpv to be maximize properly, pywin32 is also needed. The GUI component uses pystray and tkinter, but there is a fallback cli mode.
If you are using a local firewall, you’ll want to allow inbound connections on TCP 3000 and UDP 32410, 32412, 32413, and 32414. The TCP port is for the web server the client uses to recieve commands. The UDP ports are for the GDM discovery protocol.
This project is based on https://github.com/wnielson/omplex, which is available under the terms of the MIT License. The project was ported to python3, modified to use mpv as the player, and updated to allow all features of the remote control api for video playback.
Linux Installation
If you are on Linux, you can install via pip. You’ll need libmpv1 or mpv installed.
sudo pip3 install --upgrade plex-mpv-shim
If you would like the GUI and systray features, also install pystray and tkinter:
sudo pip3 install pystray
sudo apt install python3-tk
You can build mpv from source to get better codec support. Execute the following:
sudo pip3 install --upgrade python-mpv
sudo apt install autoconf automake libtool libharfbuzz-dev libfreetype6-dev libfontconfig1-dev libx11-dev libxrandr-dev libvdpau-dev libva-dev mesa-common-dev libegl1-mesa-dev yasm libasound2-dev libpulse-dev libuchardet-dev zlib1g-dev libfribidi-dev git libgnutls28-dev libgl1-mesa-dev libsdl2-dev cmake wget python g++ libluajit-5.1-dev
git clone https://github.com/mpv-player/mpv-build.git
cd mpv-build
echo --enable-libmpv-shared > mpv_options
./rebuild -j4
sudo ./install
sudo ldconfig
OSX Installation
Currently on OSX only the external MPV backend seems to be working. I cannot test on OSX, so please report any issues you find.
To install the CLI version:
- Install brew. (Instructions)
- Install python3 and mpv.
brew install python mpv - Install jellyfin-mpv-shim.
pip3 install --upgrade plex-mpv-shim - Run
plex-mpv-shim.
If you’d like to install the GUI version, you need a working copy of tkinter.
- Install pyenv. (Instructions)
- Install TK and mpv.
brew install tcl-tk mpv - Install python3 with TK support.
FLAGS="-I$(brew --prefix tcl-tk)/include" pyenv install 3.8.1 - Set this python3 as the default.
pyenv global 3.8.1 - Install jellyfin-mpv-shim and pystray.
pip3 install --upgrade plex-mpv-shim pystray - Run
plex-mpv-shim.
Building on Windows
There is a prebuilt version for Windows in the releases section. When following these directions, please take care to ensure both the python and libmpv libraries are either 64 or 32 bit. (Don’t mismatch them.)
- Install Python3 with PATH enabled. Install 7zip.
- After installing python3, open
cmdas admin and runpip install --upgrade pyinstaller python-mpv requests pywin32 pystray python-mpv-jsonipc. - Download libmpv.
- Extract the
mpv-1.dllfrom the file and move it to theplex-mpv-shimfolder. - Open a regular
cmdprompt. Navigate to theplex-mpv-shimfolder. - Run
pyinstaller -wF --add-binary "mpv-1.dll;." --add-binary "plex_mpv_shim\systray.png;." --icon media.ico run.py.
