Plex Music Organisation
Server Version#:
I have Clubland X-treme hardcore album (as a prime example) and oddly I fixed it’s tags with MP3tag issue I have in Plex is it’s organised it fine in Plex by Disc 1 - 3 but disc 1 goes 1 - 19 then 83 - 86 in numbers (These are a 1 track album mix these songs for each disc)
Disc 2 is perfect 1 - 23 with no issues
Disc 3 however is all over the place
1 - 21 is fine then goes 24, 25 27, 28, 29, 32, 33, 60 all way to 80
I’m unsure why as they all have there disc tags on tracks and I wish Plex would make anything over a certain length be separated maybe as continuous mix instead of mixed in with disc numbers
I mean theoretically I could delete the files but unsure if it would fix numbering issues.
It turns out some songs are labeled 31A & 31B
Seems Plex doesn’t know how to handle this I’m assuming hopefully it can be fixed.
Plex doesn’t support custom track numbering schemes.
Use only integer numbers.
