Plex Music - which metadata tags does Plex use?
I’ve searched many times, and the best answers I get are sort of ambiguous. The support articles give me very little assistance, referencing only four of the many tags available.
If your content already has (accurate) embedded metadata, then Plex will use that information for matching in a default install.
and
Besides having the files organized appropriately, tagging your tracks correctly can influence how well they are identified and matched. Ideally, you’ll want your tracks to have accurate “Artist”, “Album”, and “Track” tags. The “Album Artist” tag can also be very useful in cases of compilations … If you’ve enabled the Prefer local metadata advanced preference for your music library, then you must ensure that all of your music content has full, accurate metadata tags.
I know for sure that Plex also reads “genre” tags, as well as at least one of the “Year” or “Date” tags, because changing any one of those tags is reflected in Plex when you refresh the metadata.
It seems this is a well-guarded secret, because my searches for more information always end up with something like “Plex may or may not use other embedded tags”
I can’t imagine a reason for Plex to decide this information should not be revealed. The new music system is a big improvement over the old,(with a few glitches here and there) If we, as users, were able to utilize the tags that Plex actually uses, it could eliminate some of the mis-matches and unmatched artists and albums that seem to occur more often than they did with the old system.
I believe the list in this post is accurate.
I truly appreciate the work you’ve put into your feature suggestion for better tag support, and I’ve read through it quite a few times.
A lot of the tags you feel are supported or partially supported are part of the ID3 v.2.4 format, if I’m not mistaken. The same thing is true for several of the tags you would like to see implemented.
But, I’ve been told a couple of times specifically not to use v2.4 tags for Plex, and I’ve seen it recommended to others to only use v2.3. Personally, I get similar results with either, so I believe Plex supports both versions, at least at the current time.
I certainly don’t have the expertise in music tagging you have, and I use programs ike MP3Tag and Picard which convert the rather cryptic official tag names to “dumb” human names l can understand.
For example, I’m pretty sure Plex reads the TYER tag in ID3v2.3 to determine the “Originally Available” information for an album. (TDRC in v2.4, I think)
MP3Tag calls that YEAR (not to be confused with the MP3Tag’s other fields of ORIGINALYEAR or ORIGYEAR
Picard calls that same field Date (which is not the same as Original Release Date or Original Year)
LOL - I have no idea where those generic names used by the common tagging software fit in with your comprehensive (and I’m sure) accurate list. I don’t think your list even mentions the word “year” in its descriptions. It’s easy to get lost and frustrated, when all I want to know is what tag Plex uses for that field.
To make it worse, if I head over to Wikipedia to find out which tag is for the Original Release year, it tells me it is TORY or TDOR, which you have in your list as completely “un-supported.”
Please keep up with your excellent work, and I’m not here to dismiss your post in any way. I’ve run into many problems with the new music system, and I’m assuming because of embedded metadata that seemed to work with the old system very well. I’ve even Plex Danced more albums and artists in the last 2 months than I ever did with the old system in 3 or 4 years.
It shouldn’t be up to you as a user of the Plex Music sytem, to identify the tags Plex will use or not use. They re-designed the system for a richer experience, know what tags they read, what version of ID3 to use, etc., and as far as I can tell, it’s mostly speculation, nothing official.
