Plex naming movies incorrectly with no "fix match" option
Server Version#:1.24.5.5173-7000
Player Version#:na
I have uploaded several movies to Plex library. Many of these are incorrectly identified, but there is no “fix match” option to correct the problem. I have provided a snapshot with Addams Family Values as the example.
The folder is named “Addams Family Values (1993)” and the file is “Addams Family Values (1993).mp4”
The cover is correct, but the title is “5 Spooky Films” and there is no fix match option. If I select the movie and go to “edit” the Title is listed as “5 Spooky Films” and is unlocked.
My agents are The Movie Database, then Local Media Assets (Movies) in this order.!
What do I need to do to get fix match to show? It’s going to be a pain to go through hundreds of movies to edit titles.
Many thanks! Robert
Screen Shot 2021-10-26 at 9.44.28 AM
You’re looking at a collection.
Either your file has some weird embedded metadata or some joker has created a weird collection on The Movie Database (which will probably be removed quickly or has already been removed and should go away in Plex after refreshing your metadata in a few days).
