Plex no longer scans folder with changes
After a few updates, I still notice that plex will not automatically scan for changes in the folders were changes are being made. In settings I have ‘Run a partial scan when changes are detected’ selected. I’ve tried using the other option and doesn’t work either. I don’t want to use daily scan since this seems a bit over kill for my needs. Any help would be grateful.
Thank you
same problem on linux with 1.20.5.3583
i made another library but video type and specifically picked the folders that werent getting scanned and had luck triggering it to be scanned in in the video library made it show up in the tv library but im still finding videos that don’t want to scan in unless ive ran them through a converter
Same problem here…on Win64 PMS Version#: 1.20.4.3517
I’m also not able to scan/update my libraries. PMS Version 1.20.4.3517. 64-bit Windows 10 version 1909 build 18363.1198.
Windows did an update a few days ago and I haven’t updated libraries since.
My problem is resolved with the today’s PMS update. Thanks!
