I apparently have 10 streams but i have nothing showing on Plex, I have to look at Tautulli. the plex dasboard shows the bandwidth just not the streams. the Badge over the lightning bolt is blank and then i go to the dashboard it says nothing is playing while i can see other stats like Bandwidth and other. just not current streams>>>even a plugin on my unraid server can see the streams, plex dash on android shows nothing either
Plex Server Version 1.25.2.5319 running in Docker on unRAID
***Update
Restarted the container and it has come back showing the live streams again I have seen this issue a couple times so thinking its a memory leak or another bug
I’ve been jumping back and forth on my VPN here remotely daily. I keep a browser window loaded to my Plex server to keep an eye on things, but often the dashboard fails to show the active streams and some other data until I reload the page. Are you using a browser? Did you refresh that? I’d hate for this issue to simply be a browser session ending.
Yeah, I’m glad it’s working, but as a self-taught ITer, it ticks me off when I can’t find the reason why it broke in the first place. That it can happen and needs a server reboot is concerning (to me), and means it can come back. But then I get annoyed at almost everything.
