Plex no longer working as it did.
I was on a .9x version of plex before I decided to allow the upgrade. I wish (and I guess I should) have reviewed the forums before doing so. After the upgrade to 1.0.2, I could watch movies fine within my home. All moves are .wtv mpeg2 encoding /w AC3 audio format and the typical bitrate I set is 6200Kb/s. After the upgrade, I could not watch any movies remotely. ON web I would get the error message noting not able to play. On my iphone it would note that the minimum bandwidth needed to play the video was somewhere in the neighborhood of 150K (don’t recall the exact #) and the app noted that I had less than 1K available.
Home upload speed 11M/s
Remote web speed 28M/s
Remote iphone connected speed 15M/s
So speed is not the issue.
That’s when I did the research and saw all of the issues with upgrading to 1.0. Whatever the fixes were in 1.02, they don’t work for me. I decided to revert back to 0.9.16.6. I can play the movies but now the issue I have is if I leave the default on the player to play “original” speed, I get buffering. Never had this before I did the upgrade then downgrade. If I set the speed at 2Mb/s, it plays smoothly.
I know I can provide more info but any initial thoughts. Yes I would prefer to be on the latest version but with it not playing anything, that seems like a non-starter.
Please take one of the movies which doesn’t play on Plex/Web (we’ll start with the basics)…
Get the media info PMS has for it (select the film, hover on the 3 dots, get the ‘info’). Also click ‘View XML’ and grab that too. Please paste both here (using ‘Code’ paragraph formatting) so the forum doesn’t try to interpret it.
Where I’m going with this is directly at the codecs. The fundamental change between 0.9.16.6 and 1.0 is codecs are now downloaded as needed. Once you have it, you’ll never need it again.
Also, speaking to codecs, If running on Linux, check /etc/fstab and make certain the ‘noexec’ option is not present on the file system where /var/lib/plexmediaserver/Library is mounted. This will stop everything but the bare basics from running.
Below is a sample movie providing what you requested. I went and re-installed 1.0.2 with the same result. Note: I used my iphone and when connected to mobility network I get the same error. If I connect to my home wifi, the media plays.
Added note: When I revert to version 0.9.17.3.2239-fe07491, I still get the error playing the media. I have to use 0.9.16.6.1993-5089475 to play media remotely.
Media
Video Resolution 1080p
Duration 1:13:56
Bitrate 6184 kbps
Width 1920
Height 1080
Aspect Ratio 1.78
Container WTV
Video Frame Rate PAL
Video Profile main
Part
Duration 1:13:56
File 101 Dalmatians II Patch’s London Adventure (2003).wtv
Size 3.24 GB
Container WTV
Video Profile main
Codec MPEG2VIDEO
Bitrate 5800 kbps
Bit Depth 8
Chroma Subsampling 4:2:0
Color Range tv
Frame Rate 25 fps
Height 1080
Pixel Format yuv420p
Profile main
Scan Type progressive
Stream Identifier 2
Width 1920
Codec AC3
Channels Stereo
Bitrate 384 kbps
Audio Channel Layout stereo
Sampling Rate 48000 Hz
Stream Identifier 3
Codec SRT
Language English
Format SRT
Codec SUB
Language English
Format MICRODVD
xml
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="14" librarySectionTitle="Family 2D" librarySectionUUID="cbb8ffd5-2d3c-4402-a52b-40318affdcc6" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1468878634"> <Video ratingKey="82818" key="/library/metadata/82818" guid="com.plexapp.agents.imdb://tt0324941?lang=en" librarySectionID="14" studio="Walt Disney Pictures" type="movie" title="101 Dalmatians II: Patch's London Adventure" contentRating="G" summary="A direct-to-video sequel Roger, Anita and their canine clan are packing for the big move to Dalmatian Plantation, a home in the country with plenty of room for the 101 pups and far from the clutches of Cruella DeVil. The feistiest pup, Patch, feels lost in a sea of spots and longs to be a one-of-a-kind wonderdog like his TV hero,." rating="5.7" audienceRating="4.1" year="2003" tagline="A New Hero Unleashed." thumb="/library/metadata/82818/thumb/1469434423" art="/library/metadata/82818/art/1469434423" duration="4436605" originallyAvailableAt="2003-01-21" addedAt="1446511929" updatedAt="1469434423" audienceRatingImage="rottentomatoes://image.rating.spilled" chapterSource="agent" ratingImage=""> <Media videoResolution="1080" id="183074" duration="4436605" bitrate="6184" width="1920" height="1080" aspectRatio="1.78" audioChannels="2" audioCodec="ac3" videoCodec="mpeg2video" container="wtv" videoFrameRate="PAL" videoProfile="main"> <Part accessible="1" exists="1" id="184203" key="/library/parts/184203/1446504591/file.wtv" duration="4436605" file="V:\Media\2D Family\101 Dalmatians II Patch's London Adventure\101 Dalmatians II Patch's London Adventure (2003).wtv" size="3480588288" container="wtv" videoProfile="main"> <Stream id="411939" streamType="1" codec="mpeg2video" index="0" bitrate="5800" bitDepth="8" chromaSubsampling="4:2:0" colorRange="tv" frameRate="25.000" height="1080" pixelFormat="yuv420p" profile="main" scanType="progressive" streamIdentifier="2" width="1920"/> <Stream id="411940" streamType="2" selected="1" codec="ac3" index="1" channels="2" bitrate="384" audioChannelLayout="stereo" samplingRate="48000" streamIdentifier="3"/> <Stream id="415442" key="/library/streams/415442" streamType="3" codec="srt" language="English" languageCode="eng" format="srt"/> <Stream id="412063" key="/library/streams/412063" streamType="3" codec="sub" language="English" languageCode="eng" format="microdvd"/> </Part> </Media> <Genre id="98" tag="Animation" count="388"/> <Genre id="3138" tag="Family" count="526"/> <Director id="13969" tag="Jim Kammerud" count="3"/> <Director id="58440" tag="Brian Smith" count="2"/> <Writer id="58441" tag="Jim Kammerud"/> <Writer id="58442" tag="Brian Smith"/> <Country id="27" tag="USA" count="531"/> <Collection id="13071" tag="101 Dalmatians Animated" count="2"/> <Role id="57529" tag="Barry Bostwick" count="2" role="Thunderbolt" thumb="http://image.tmdb.org/t/p/original/p25f5yLOLqhFC40RmcxAmWDLtP4.jpg"/> <Role id="13981" tag="Jason Alexander" count="4" role="Lightning" thumb="http://image.tmdb.org/t/p/original/ernpSXp2RnkzeV14OEEKXRq1yND.jpg"/> <Role id="2089" tag="Martin Short" count="10" role="Lars" thumb="http://image.tmdb.org/t/p/original/oZQorXBjTxrdkTJFpoDwOcQ91ji.jpg"/> <Role id="58443" tag="Bobby Lockwood" role="Patch" thumb="http://image.tmdb.org/t/p/original/jLJGSYpm7yL0zORYuXoVbs8eqeu.jpg"/> <Role id="5747" tag="Susanne Blakeslee" count="5" role="Cruella de Vil" thumb="http://image.tmdb.org/t/p/original/mJ3dkcAX9STU3SPN06IsTltham8.jpg"/> <Role id="58444" tag="Samuel West" role="Pongo" thumb="http://image.tmdb.org/t/p/original/w6L9AZSFx1n3O4fDcAml6BDt1t.jpg"/> <Role id="6624" tag="Maurice LaMarche" count="11" role="Horace" thumb="http://image.tmdb.org/t/p/original/zanuPXm0BYAsARbsrDMjLmct7Fq.jpg"/> <Role id="12061" tag="Jeff Bennett" count="31" role="Jasper" thumb="http://image.tmdb.org/t/p/original/bms3A7TA0QItjtUlB28qv4MFFAH.jpg"/> <Role id="4827" tag="Jodi Benson" count="8" role="Anita" thumb="http://image.tmdb.org/t/p/original/9tOpKgu6cBBL29LxEC21fOVVVPW.jpg"/> <Role id="33236" tag="Tim Bentinck" role="Roger" thumb="http://image.tmdb.org/t/p/original/5ivB3NASupoKcc4RShs8E3PIPP3.jpg"/> <Role id="78" tag="Kath Soucie" count="15" role="Perdita" thumb="http://image.tmdb.org/t/p/original/urLkA155Yc19TKyeCUYGwzEt2PO.jpg"/> <Role id="58445" tag="Mary MacLeod" role="Nanny" thumb="http://image.tmdb.org/t/p/original/q1ai6EaCywRV6TaegMTqwuPfOf7.jpg"/> <Role id="631" tag="Michael Lerner" role="Producer" thumb="http://image.tmdb.org/t/p/original/nJaZ9MIhfz4KEwZka5Iu1SUC9CI.jpg"/> <Role id="58446" tag="Scott Alan Berk" role="Salvador Dali" thumb="http://image.tmdb.org/t/p/original/wEDhW3nmnezjI5jLmHuSnhsgrVP.jpg"/> <Role id="58447" tag="Kasha Kropinski" role="Penny" thumb="http://image.tmdb.org/t/p/original/5KVy0oXVdjSXW3WOLA23G52Ld0a.jpg"/> <Role id="58448" tag="Ben Tibber" role="Lucky" thumb="http://image.tmdb.org/t/p/original/bZerEBKRFIuZ11ip0CYzqFMpq0P.jpg"/> <Extras size="0"></Extras> </Video> </MediaContainer>
As a way of focusing in on the core issue, have you tested playing with and without subtitles turned on?
Also, if easily doable, can you create a test version of the file with subtitles completely removed? (mkvtoolnix can strip subtitles easily)
By default subtitles are off but to satisfy the question I ran this same movie with and without subtitles and it did not work. I tried with and without subtitles in .9.17 and it played fine. A 30 second version of the movie is below.
https://app.box.com/s/iflyk91y519yu2bz6za2c9g72g6q0b5x
@Chuckpa any thoughts?
I have also had problems with the recent release. The main issue is that movies that played perfectly through Google ChromeCast before now just start, stutter and then stop. If I play the same move through my iPad or the Samsung SmartTV Plex client then all is fine. Other than the recent software update, I have not changed any settings.
I an running Plex MS on a QNAP TS-543 Pro, the CPU is the Intel® Celeron® CPU J1900 @ 1.99GHz
I an running Plex MS on a QNAP TS-543 Pro, the CPU is the Intel(R) Celeron(R) CPU J1900 @ 1.99GHz
Best to create your own thread instead of hijacking this one.
@ Chuckpa. I tried installing the latest update ver 1.1.0 and the same issue occurs.
Using Plex Web, go to a movie and hit “Analyze”, then try playing it back remotely. I believe there was a bug in 1.0.2 that this analysis did not work properly. With 1.1.0, this is fixed but the analysis does not automatically occur. It will eventually if you have that set as a schedules task but this will update it for 1 movie. If this works, run “Analyze” for every library and you should be ok from then on.
I’ll try that. Will provide feedback.
Update: I tried that and the same issue occurred for remote access. I tried multiple movies to ensure I do a thorough test. Also, I used my iphone and connected to my lan and of course the movie played fine. Remote…not so much.
Ok, we’re going to need to see the log from both the server and the client after you try playing remotely. It really shouldn’t matter how you access the server.
With PMS shut down, If you will snapshot (collect and set aside) all the Plex Media Server log files. This will give us fresh logs “from the beginning”.
Now, with your iPhone on cellular only (no wifi), start PMS and start a playback of what you know will fail. Please try to minimize your browsing around at other things. Try to be surgical in your recreation.
After that fails, enable wifi again and repeat the same invocation. As soon as you know it will be fine, stop playback.
Wait 60 seconds for PMS to quiesce and then shut it down, collect all the new Plex Media Server log(s) in a zip/tar and post here as MovieFan suggested.
I’m dumbfounded as to why but for some reason when I reinstalled the latest update this morning and tested remotely, all movies I tested played fine. I tested the ones I always used and validated with some others and had zero issues. I did nothing different other than to do my 10th or 11th re-install and for some reason it is working.
For now I’ll call it luck and leave the new version running. If the issue returns, I’ll follow the note above and open a new case.
Thanks all for your help.
