Plex not able to start (Permissions problem?)
OS#: Ubuntu 20.04.1 LTS
Server Version#: 1.21.0.37
So I have a server, and I was trying to set up Transmission and Flexget. Honestly, I’m just starting with all these, I think I messed up the permissions, Plex won’t start now :woman_facepalming: These are the only logs I see.
I tried removing it entirely and reinstall it again, but that didn’t help.
● plexmediaserver.service - Plex Media Server
     Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
    Drop-In: /etc/systemd/system/plexmediaserver.service.d
             └─override.conf
     Active: failed (Result: exit-code) since Mon 2020-12-14 12:49:43 CET; 21min ago
    Process: 5744 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" >
    Process: 5748 ExecStart=/bin/sh -c  export PLEX_MEDIA_SERVER_INFO_VENDOR="$(grep ^NAME= /etc/os-release | awk -F= "{print \$2}" | tr -d \" )";  export PLEX_MEDIA_SERV>
   Main PID: 5748 (code=exited, status=1/FAILURE)
dec 14 12:49:43 server systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 3.
dec 14 12:49:43 server systemd[1]: Stopped Plex Media Server.
dec 14 12:49:43 server systemd[1]: plexmediaserver.service: Start request repeated too quickly.
dec 14 12:49:43 server systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
dec 14 12:49:43 server systemd[1]: Failed to start Plex Media Server.
I tried https://askubuntu.com/a/1274738/1107385 but no luck yet
What’s the output of the command ls -l / ?
Run the list of possibilities:
  1. systemctl status plexmediaserver
    a. verify the override.conf is showing – if used for your config
  2. grep plex /etc/passwd
  3. ls -la /var/lib/plexmediaserver
lrwxrwxrwx   1 root root          7 dec 12 14:46 bin -> usr/bin
drwxr-xr-x   4 root root       4096 dec 12 15:27 boot
drwxrwxr-x   2 root root       4096 dec 12 14:49 cdrom
drwxr-xr-x  19 root root       4480 dec 14 12:33 dev
drwxr-xr-x   2 root root       4096 dec 12 16:44 disk1
drwxr-xr-x 139 root root      12288 dec 14 12:46 etc
drwxr-xr-x   4 root root       4096 dec 13 00:08 home
lrwxrwxrwx   1 root root          7 dec 12 14:46 lib -> usr/lib
lrwxrwxrwx   1 root root          9 dec 12 14:46 lib32 -> usr/lib32
lrwxrwxrwx   1 root root          9 dec 12 14:46 lib64 -> usr/lib64
lrwxrwxrwx   1 root root         10 dec 12 14:46 libx32 -> usr/libx32
drwx------   2 root root      16384 dec 12 14:45 lost+found
drwxr-xr-x   4 root root       4096 dec 12 17:12 media
drwxr-xr-x   2 root root       4096 jul 31 18:27 mnt
drwxr-xr-x   3 root root       4096 dec 12 21:47 opt
dr-xr-xr-x 233 root root          0 dec 14 12:32 proc
drwx------   6 root root       4096 dec 12 16:23 root
drwxr-xr-x  35 root root        960 dec 14 21:07 run
lrwxrwxrwx   1 root root          8 dec 12 14:46 sbin -> usr/sbin
drwxr-xr-x  10 root root       4096 dec 12 15:10 snap
drwxr-xr-x   2 root root       4096 jul 31 18:27 srv
-rw-------   1 root root 2147483648 dec 12 14:45 swapfile
dr-xr-xr-x  13 root root          0 dec 14 12:32 sys
drwxrwxrwt  22 root root       4096 dec 14 16:26 tmp
drwxr-xr-x  14 root root       4096 jul 31 18:28 usr
drwxr-xr-x  14 root root       4096 jul 31 18:35 var
:pleading_face:
             └─override.conf
     Active: failed (Result: exit-code) since Mon 2020-12-14 16:25:55 CET; 4h 44min ago
    Process: 9314 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" (code=exited, statu>
    Process: 9321 ExecStart=/bin/sh -c  export PLEX_MEDIA_SERVER_INFO_VENDOR="$(grep ^NAME= /etc/os-release | awk -F= "{print \$2}" | tr -d \" )";  export PLEX_MEDIA_SERVER_INFO_DEVICE="PC">
   Main PID: 9321 (code=exited, status=1/FAILURE)
dec 14 16:25:55 server systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 3.
dec 14 16:25:55 server systemd[1]: Stopped Plex Media Server.
dec 14 16:25:55 server systemd[1]: plexmediaserver.service: Start request repeated too quickly.
dec 14 16:25:55 server systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
dec 14 16:25:55 server systemd[1]: Failed to start Plex Media Server.
  1. grep plex /etc/passwd
plex:x:998:998::/var/lib/plexmediaserver:/usr/sbin/nologin
  1. ls -la /var/lib/plexmediaserver
total 12
drwxr-xr-x  3 plex plex 4096 dec 14 12:46 .
drwxr-xr-x 71 root root 4096 dec 14 12:46 ..
drwxr-xr-x  3 plex plex 4096 dec 14 12:46 Library
Lemme know if there’s any other info I can provide
See what’s in override.conf
that’ll drive what PMS looks for and which UID/GID it uses.
YES! Indeed there was something wrong there! It’s working OMG. Thanks!
I installed Plex on a Raspberry Pi following instruction online and on first bootup, I am having the same error but I don’t know how to fix this as I am new to this. Thanks.
Warning: The unit file, source configuration file or drop-ins of plexmediaserver.service changed on disk. Run 'systemc
└─override.conf
Active: failed (Result: exit-code) since Fri 2020-12-25 23:02:40 EST; 2min 14s ago
Process: 944 ExecStartPre=/bin/sh -c /usr/bin/test -d "{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir - Process: 946 ExecStart=/bin/sh -c export PLEX_MEDIA_SERVER_INFO_VENDOR="(grep ^NAME= /etc/os-release | awk -F= "{p
Main PID: 946 (code=exited, status=1/FAILURE)
Dec 25 23:02:40 raspberrypi systemd[1]: plexmediaserver.service: Service RestartSec=5s expired, scheduling restart.
Dec 25 23:02:40 raspberrypi systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 3.
Dec 25 23:02:40 raspberrypi systemd[1]: Stopped Plex Media Server.
Dec 25 23:02:40 raspberrypi systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Dec 25 23:02:40 raspberrypi systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
Dec 25 23:02:40 raspberrypi systemd[1]: Failed to start Plex Media Server.
how do I see what’s in override.conf?
what’s the command?
thanks
We are able to help with Plex on Linux but not setup to teach Linux.
Thanks. I searched a little more and found these errors:
pi@raspberrypi:/etc/systemd/system $ sudo journalctl -xe | grep -i plex
Dec 25 23:02:22 raspberrypi systemd[1]: Starting Plex Media Server…
– Subject: A start job for unit plexmediaserver.service has begun execution
– A start job for unit plexmediaserver.service has begun execution.
Dec 25 23:02:22 raspberrypi systemd[1]: Started Plex Media Server.
– Subject: A start job for unit plexmediaserver.service has finished successfully
– A start job for unit plexmediaserver.service has finished successfully.
Dec 25 23:02:24 raspberrypi Plex Media Server[507]: PMS: failure detected. Read/write access is required for path: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server
Dec 25 23:02:24 raspberrypi systemd[1]: plexmediaserver.service: Main process exited, code=exited, status=1/FAILURE
– An ExecStart= process belonging to unit plexmediaserver.service has exited.
Dec 25 23:02:24 raspberrypi systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
– The unit plexmediaserver.service has entered the ‘failed’ state with result ‘exit-code’.
How can I resolve this error? Thank you…
Look at what it’s telling you.
  1. Permission problem.
The username you’re trying to run as doesn’t Own / have Read-Write access to /var/lib/plexmediaserver and all below it.
What does that make you think of? hint: override.conf & chown :slight_smile:
I found another post which you helped another user
After a day of research, I learned enough Linux commands to be able to use the command chown -R myuser /var/lib/plexmediaserver and added the myuser to have Read-Write access. Plexmediaserver is up and running. I didn’t have to go into the override.conf file, thankfully, because I don’t know enough yet to know what to do in the file.
Thanks for your help!
