Server Version#: 1.40.5.8921
Player Version#: 1.40.5.8921
I completed a new install for Alma Linux 9.6 and installed plexmediaserver-1.42.1.10060-4e8b05daf.x86_64.rpm. Plex started and metadata was displayed correctly. However trying to start a video results in the gold beachball spinning and it eventually times out. I tried an install of plexmediaserver-1.40.5.8921-836b34c27.x86_64.rpm.
Same results. I read a forum page on permissons. I used usermod -a -G markb plex. Which should add plex to the user group markb. Playing a video will now work 1 or 2 times then it reverts back to the spinning beach ball. All the plexmediaserver files are assigned to plex:plex.
All the media files are assigned to markb:markb. The previous installation on Alma Linux 8 had exactly the same permissions and worked fine for months. I’m missing some small (large?) detail. see attached logs files.
I get the same spinning beachball effect on chrome, firefox, iPad Plex app, Windows Plex app.
Nov 08, 2025 16:11:31.997 [139943648729912] WARN - Warning: ex: boost::filesystem::last_write_time: No such file or directory [system:2]: “/media/virtual/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins”, couldn’t check file: “/media/virtual/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins”
Did you create a systemd override.conf or a symlink?
PMS itself isn’t running right. It crashed several times in these logs.
Before starting PMS the first time, let’s check the obvious (sorry)
Created the base mount point dir (mkdir -p),
Set plex:plex as owner
set permisions chmod -R 755 mount_point_dir
Now do the mount
chmod again
Now let PMS start up the first time and create all the sub structure as well as download all the required submodules (plug-ins – which you don’t have ---- and – likely don’t have the codecs yet either ?)
no transplant. I had a working AL (AlmaLinux) 8.6 install with a working Plex 1.42 install. There were some issues with the AL 8.6 install. So I wiped the 8.6 install and upgraded to AL 9.6.
Installed plex 1.42 to the new AL 9.6 install and used the existing /media/virtual/plexmediaserver/* files. New OS and plex using the existing working plexmediaserver directory.
This is Linux telling us it cannot complete the file io.
Nov 09, 2025 17:06:47.498 [139840940841616] ERROR - SQLITE3:0x80000001, 5386, os_unix.c:40311: (19) mmap(/media/virtual/plexmediaserver/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-shm) - No such device
Nov 09, 2025 17:06:47.498 [139840940841616] ERROR - SQLITE3:0x80000001, 5386, disk I/O error in "PRAGMA cache_size=512"
Nov 09, 2025 17:06:47.498 [139840940841616] ERROR - Promise destroyed without handling exception: Promise fell out of scope without resolving or rejecting
I seriously question whether or not this distro & version is compatible with PMS.
