Server Version#: 1.20.3.3483-211702a9f
Player Version#: 5.3.1
Platform Version: 4.8.0
Hi!
This problem has been bugging me for a very long time now and I had enough. I can’t find any help online so I’m opening this topic.
I watch a lot of anime and series (also movies somethimes) throug Plex and it used to be fine but it’s a mess right now. I use .srt and .ass subtitle files and Plex randomly not recognising the subtitles. Sometimes it’s the whole series, sometimes it’s only a couple of episodes. On the problematic episodes if I chose the option to upload a subtitle file or search for online and I select a file it will not appear in the list.
The above is only when I add the media as series. If I add it as other video than the subtitle files work perfectly all the time. The problem is that I want to add them as series for the metadata and everything.
Another problem I have is sometimes when I turn on subtitles for a movie the sound disappears. Subtitle on - no sound. Subtitle off - there is sound.
I always use .mkv files. I’m not an expert so I can’t really give more info. If more information is needed plese let me know and I’ll try to dig deeper.
Here is an example:
This is an anime I just wanted to start watching and have this problem.
Format : Matroska
Format version : Version 2
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 23mn 37s
Nominal bit rate : 9 000 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.181
Writing library : x264 core 92 r1510 33d382a
Encoding settings : cabac=1 / ref=4 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=0.90:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=9000 / ratetol=1.0 / qcomp=0.80 / qpmin=10 / qpmax=28 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.90
Audio
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Duration : 23mn 37s
Bit rate mode : Variable
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
Language : Japanese
In this case some of the episodes have subtitle but 4 of them don’t get recognised by plex.
Thank you in advance for everyone.
I’ll try renaming the folder next time.
