It looks like the things that aren't matching in that log file are mostly things that aren't quite movies (like TV documentaries and stand-up comedy shows?). You might have better luck with some of those things if you move them to a TV section, or create a Home Movies section and stick them in there.
Thanks for having a look at the log. It may not be clear from that file, but the stand-up comedy is already in my Movies section, multi series documentaries are already in the TV Shows section, and as advised on IRC the only way to get correct metadata matches for single one off episode documentaries (or even to display them in Plex when there is no metadata) is to put them in the Movies section as they already are or a section that scans TheMovieDB. This means two separate folders for documentaries which seems counter intuitive, and I am hoping to learn I can have one somehow where the appropriate metadata is matched - it seems this would mean a section scanning both TheMovieDB and TheTVDB. Please see my quote from another thread at the end of this post.
I already intend to move stand-up its own TheMovieDB scanning section as it would seem neater than putting it in with Movies. Where stand-up is at the moment should still work though, because when I click on 'Fix incorrect match' Plex either immediately suggests the correct metadata, or when I then click 'Custom search' and tell it to use TheMovieDB it suggests it instead. Please see the examples I posted previously.
Unless they're things that Freebase or The TVDB know about, the agents won't be able to grab full metadata for them.
That is just it, the majority of the media is in sections where I have confirmed through 'fix incorrect match' and/or 'custom search' the correct metadata is available but it is just not being matched automatically. There is a minority of what might be considered obscure video not matching because the metadata is simply not available and I list that media now so you can differentiate looking at the fresh log attached below log:
Movies:
Ahmadinejad The Populist and The Pariah
The Imagineers
North Korea a State of Mind
Peter Kay Live & back on Nights
Ross Noble Hammersmith
Wild, Lemurs of Madagascar
TV Shows:
Myra Hindley: The Untold Story
See No Evil: The Moors Murders
Anomalies:
Strangely, 'Adam Hills Live' - searching Freebase and TheMovieDB from fix incorrect match yields no results at all, but checking themoviedb.com shows one listing for Adam Hills Live in the Suburbs, are these names not close enough for Plex to at least suggest a match when I manually search? Alan Davies Live - same deal although the match Plex does not display even on manual search this time is exactly the same as the title.
Everything else not matching:
Has the metadata available immediately when I click on 'fix incorrect data' and then 'Match using TheMovieDB' where necessary. Basically Plex will find the metadata for this media with various degrees of prodding and I wondering why it does not do it automatically like with all the rest of the media, and if there is a way to fix the problem?
Quote from another thread on documentaries having to reside in two separate sections for Plex to metadata match them properly:
TVDB has been an excellent tool for teaching me how to label my media so they show up correctly. My quibble is this: What about one-offs like "TITANIC: The Final Word with James Cameron?"
Firstly, I love Plex and I appreciate the hard work of developers, but I also agree with you completely.
For future reference, how should I treat single instance TV documentaries? I'm not too fond of the idea of creating folders named after the channels they aired on just to house a single instance documentary. I know some could be placed in the Movies folder like "The Rape of Europa" but still...
I am new to Plex but from what someone more experienced told me yesterday one off documentaries (or anything that is shown on TV but not part of a series) do not belong in the TV Shows directory. Instead, in order for Plex to properly find and display the metadata for this media it must be placed in the Movies section so Plex can check TheMovieDB for the metadata. Personally, movies to me refers only to video that has been released into a theatre or cinema, whether fiction or non-fiction, although I guess made for TV one off movies also count - strictly drama though, otherwise the one off is a documentary.
This all does not seem so bad when you consider we can leave our regular Movies section as is, and just create a separate Documentaries directory which would scrape TheMovieDB for our one off documentaries. What does make it seem wrong is that we are now stuck documentaries stuck in two different directories, one offs in one, series documentaries in another.
We could create the following directory structure although it seems complicated and sloppy: Movies, Documentaries, Documentary Series, TV Shows.
Can somebody please tell me I have been misinformed and that somehow there is a way to have Plex properly display the metadata for all TV documentaries, whether one offs or series, either in TV Shows or a single Documentaries directory? It seems this would involve a directory scanning TheMovieDB and TheTVDB.
In this lucky instance PLEX was able to glean enough information from the media file to correctly dump it inside a National Geographic Documentaries file but I for the life of me can't find the information at TVDB that made PLEX do that. I'm very ■■■■ about my documentaries and always want to know why something went where it did and this frustrates me.
When you say Plex was able to glean enough information to correctly dump it inside the National Geographic Documentaries file - do you mean the your National Geographic Documentaries directory/folder on your drive? If so, how do I enable this?
Also, do any of you know of a way to automatically appropriately rename and relocate documentaries so that Plex can pick them up? When I say automatically I mean something we can leave running that does this in our absence whenever media appears in a specified folder, rather than constantly having to manually do it with something like filebot.
