Server Version#: 1.41.0.8994
Player Version#: 10.22.1.1607
Neither Plex nor Plexamp will show song titles, but web player works works fine
Can you provide a screen shot? I see song titles right under the time line.
I cannot recreate in the current Android app V 10.23.0
Do you have some unusual system settings for text size or zoom?
I did have text size bumped up 1 notch, but I reset it and no difference
Which Android version is running on this device?
Tablet and Phone are running 15
Do you have other Android devices with older versions? Just for checking whether it might be caused by this brand new version of Android.
I don’t have access to any devices running 14 still. I did look at it using the ios app and it shows titles but all of the track numbers are 0.
When is v10.23 hitting the Play Store?
It should already be out. Plex for Android - #521 by PlexAndroidReleaser
But due to the “staged rollout” methodology, it can take a few days until it arrives at your particular device. If you’re using the Amazon app store it can take even longer.
