Plex not listing same number of channels as scan
Server Version#: Version 1.19.1.2645 Windows 10
Tuner Make/Model: WinTV-quadHD
Have a WinTV-quadhd and during the Plex Live TV scan the screen shows ~300 channels found but when completed it only lists 74 to verify.
The WinTV app that came with the tuner finds all the channels as expected, but Plex does not.
Is there something that can be done to correct the scanning?
Thanks in advance. Shawn
what channel list did you tick to scan for?
Plex uses predefined channel lists depending on the choosed provider. Have you tried to use another list? Same issue?
