Plex not parsing XML file correctly
Server Version#: 1.28.2.6151
Player Version#: 4.91.2
Tuner Make/Model: WinTV-dualHD and xTeVe
Guide/Lineup name: xTeVe fed by Guide2Go
Using XMLTV?: Yes
Channel number/Name: 2.1, 2.2, 2.3, 2.4, 4.1, 4.2, and more
Issue
Plex is not parsing the XML file correctly. Plex will show shows on at the same time when that is not possible. It looks like Plex is confusing channel numbers. I have verified using XMLTV EPG Viewer (By Ian Bishop), Nxtvepg by T. Zorner, and by inspecting the XML file by hand that the XML file is not corrupt.
Examples
This shows channel 2.1 with Adam-12 and Judge Judy at the same time. Same with Fox 2 News at 5:00pm and The A-Team. Details are below.
Adam-12 Information
Judge Judy Info
A-Team Info
FOX 2 News info
After manually looking at the XML in Notepad++ it looks like Plex is somehow putting the information from channel 24.1 inside of channel 2.1.
Adam-12 on 24.1
The A-Team on 24.1
More Info
This is also happening on other channels.
I have a copy of the XML file handy and will gladly send it to a Plex dev however I would rather not post it publicly on the forums is possible.
Thank you for any help with this.
So you have both WinTV and xTeVe added to the same guide? In this scenario you have two different tuners added…
How are the channel numbers named for xTeVe? The WinTV would be like 2.1 4.1 7.1 7.2 7.3 … and is xTeVe just normal without the periods? eg: 50 51 52 53
Do you see the same as this?
