Server Version#: 1.41.1.9057
Player Version#: 4.141.0
Tuner Make/Model: HAUPPAUGE WinTV-DualHD 1595
Guide/Lineup name: NA
Using XMLTV?: Yes
Channel number/Name: 13-1 WQEDDT
When I run a scan in Plex I’m unable to get channel 13-1 through 13-5. I can get pretty much every other channel in the area except this one. I tried using the same tuner and antenna setup on a different computer and I can easily pick up that channel when using w_scan. It’s not a reception issue. Why is Plex not able to pick up this channel? Is there any way to manually add this channel?
