merval
April 14, 2021, 4:17am
1
Server Version#: 1.22.2.4282 (I’ve seen this in the logs for many version though)
Player Version#: Unknown
Apr 13, 2021 21:07:33.872 [0x70000671e000] Debug — NetworkServiceBrowser: Parsing SSDP schema for http://192.168.1.x:9080
Apr 13, 2021 21:07:33.872 [0x70000671e000] Debug — HTTP requesting GET http://192.168.1.x:9080
Apr 13, 2021 21:07:33.879 [0x70000671e000] Debug — HTTP/1.1 (0.0s) 200 response from GET http://192.168.1.x:9080 (reused)
Apr 13, 2021 21:07:33.879 [0x70000671e000] Error — XML: Entity: line 1:
Apr 13, 2021 21:07:33.879 [0x70000671e000] Error — XML: parser
Apr 13, 2021 21:07:33.879 [0x70000671e000] Error — XML: error :
Apr 13, 2021 21:07:33.879 [0x70000671e000] Error — XML: Start tag expected, ‘<’ not found
Apr 13, 2021 21:07:33.879 [0x70000671e000] Error — XML: status=ok
Apr 13, 2021 21:07:33.879 [0x70000671e000] Error — XML: ^
Apr 13, 2021 21:07:33.879 [0x70000671e000] Error — Error parsing content.
Apr 13, 2021 21:07:33.879 [0x70000671e000] Error — Error parsing XML: Error parsing file.
Apr 13, 2021 21:07:33.879 [0x70000671e000] Error — SSDP: Error parsing device schema for http://192.168.1.x:9080
Is this to be expected?
Several issues with multiple Fire tv / Firestick models and the new updates
Continue watching, resume, homescreen, ect…
Plex is aware of this but you may want to try searching for different threads on this subject to see if the problems you’re having are similar
You can safely ignore these log entries. They’re the result of Plex Media Server sending SSDP multicast queries on your network. Without getting too deep in the weeds, when your Fire TV replies it does so with a URL from which the querying server (Plex) can ask for more information. When Plex accesses this URL, it doesn’t find the schema it expects and logs the error.
There is currently no way (in Plex) to disable these queries entirely. The best you can do is use a firewall on your server to block certain traffic to UDP port 1900 (or block SSDP replies from the offending devices).
Another recent thread:
Server Version#: 1.21.3.4046
Are these errors normal and expected?
192.168.1.196: Luxshare Precision Industry Com
192.168.1.52: FireTV
192:168.1.128: FireTV
Looking at Console / Filter: Errors
Feb 25, 2021 11:18:14.578 [10540] Error — XML: Entity: line 1:
Feb 25, 2021 11:18:14.578 [10540] Error — XML: parser
Feb 25, 2021 11:18:14.578 [10540] Error — XML: error :
Feb 25, 2021 11:18:14.578 [10540] Error — XML: Start tag expected, '<' not found
Feb 25, 2021 11:18:14.578 [10540] Error — XML:…
