Server Version#: 1.19.3.2764-ef515a800
Player Version#: Web 4.30.2
So I’m having the hardest time getting Plex to behave correctly. I switched to running my server on a ssd in windows 10 pc. I haven’t been able to correctly get my movies database finished for many days. I’m having different types of strange behavior. I added a folder to the library and it wont scrape a lot of films all named correctly with Filebot and scrapped fine before. So I tried going through the tedious process of removing them 1 by 1 to do the Plex dance, except that Plex doesn’t add them to the trash upon rescaning. In fact, it finally started downloading metadata for the files that are not even there anymore. I’m about to delete the whole thing it’s so frustrating. Each time I get around one thing something else pops up. Is there some way someone can tell me what’s going on here? If I have a corrupted install or something?
BTW, my files are hosted on local drives and a nas drives mapped to the pc.
Thanks in advance!
Plex Media Server Logs_2020-05-13_03-15-57.zip (3.5 MB)
Plex Media Server Logs_2020-05-13_03-17-08.zip (3.6 MB)
I’m not sure if these logs will be helpful;I just noticed debugging was disabled (1st log), so I enabled it (2nd log), just in-case its helpful.
May 13, 2020 03:03:32.463 [0572] WARN - HTTP error requesting GET http://127.0.0.1:32400/:/metadata/updateProgressMessage?message=Scanning%20BluRay (7, Couldn’t connect to server) (Failed to connect to 127.0.0.1 port 32400: Address already in use)
Your logs indicate that something else is also using port 32400 on your computer.
Oh wow, that explains why I’m still having issues after a clean install. I wonder if that’s something to do with the NAS. Is there someway I can easily identify what’s using that port? I didn’t see anything obviously in windows firewall.
Thank you so much for taking a look for me. I guess I could have spotted that if I attempted, but I never looked at a log file before, so thank you!
For others interested you can run a pair of command in command prompt to identify whats using specific ports:
Check what program ID is using port 8080.
netstat -aon | findstr 32400
It will results a list with PID #
Check what program has that ID
tasklist | findstr PID#
With this I was able to identify 3 Plex services and chrome using this port.
Now it was Plex using that port on the chrome webui I believe. How am I supposed to manage the server updating and processing without being able to open the UI?
Can you provide the results of the netstat command?
So I opened the Plex UI from the Plex homepage instead of my server, incase that was the issue. I don’t have the results with chrome anymore because I closed the cmd window. I ran it again and go this:
TCP 127.0.0.1:59592 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59595 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59598 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59603 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59604 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59613 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59614 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59617 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59673 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59676 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59679 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59684 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59685 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59694 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59695 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59698 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59769 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59772 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59775 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59780 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59781 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59790 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59791 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59795 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59863 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59866 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59869 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59874 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59875 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59884 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59885 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:59888 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60002 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60005 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60008 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60013 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60014 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60023 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60024 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60027 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60091 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60094 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60097 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60102 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60103 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60112 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60113 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60116 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60154 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60157 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60160 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60165 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60166 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60181 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60182 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60186 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60230 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60233 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60236 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60241 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60242 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60251 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60252 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60255 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60305 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60308 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60311 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60316 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60317 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60327 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60328 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60331 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60400 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60403 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60406 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60411 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60412 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60421 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60422 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60426 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60502 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60505 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60508 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60513 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60514 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60523 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60524 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60527 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60611 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60614 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60617 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60622 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60623 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60632 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60633 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60636 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60670 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60673 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60676 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60681 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60682 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60693 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60694 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60697 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60788 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60791 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60794 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60799 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60800 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60809 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60810 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60813 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60890 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60893 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60896 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60901 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60902 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60911 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60912 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60915 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60970 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60973 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60976 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60981 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60982 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60992 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60993 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:60996 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61041 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61044 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61047 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61052 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61053 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61062 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61063 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61066 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61126 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61129 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61132 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61137 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61138 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61147 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61148 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61151 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61218 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61221 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61224 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61229 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61230 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61239 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61240 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61243 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61303 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61306 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61309 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61314 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61315 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61322 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61325 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61328 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61443 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61446 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61449 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61455 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61456 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61466 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61467 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61470 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61546 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61549 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61552 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61557 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61558 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61567 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61568 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61571 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61616 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61619 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61622 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61627 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61629 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61638 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61639 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61642 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61711 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61714 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61717 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61722 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61723 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61732 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61733 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61736 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61785 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61788 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61791 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61796 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61797 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61807 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61808 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61811 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61868 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61871 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61874 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61879 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61880 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61889 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61890 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61893 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61966 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61969 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61973 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61978 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61979 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61988 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61989 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:61992 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62058 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62061 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62064 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62069 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62070 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62079 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62080 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62083 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62133 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62136 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62139 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62144 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62145 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62154 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62155 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62158 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62240 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62243 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62246 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62251 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62252 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62261 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62262 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62265 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62369 127.0.0.1:32400 ESTABLISHED 7476
TCP 127.0.0.1:62378 127.0.0.1:32400 ESTABLISHED 7476
TCP 127.0.0.1:62401 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62404 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62407 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62412 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62413 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62422 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62423 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62426 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62462 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62465 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62468 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62473 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62474 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62483 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62484 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62487 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62524 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62527 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62530 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62535 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62536 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62545 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62546 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62549 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62595 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62598 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62601 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62606 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62607 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62617 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62618 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62621 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62675 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62678 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62681 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62686 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62687 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62696 127.0.0.1:32400 ESTABLISHED 10080
TCP 127.0.0.1:62697 127.0.0.1:32400 TIME_WAIT 0
TCP 127.0.0.1:62701 127.0.0.1:32400 ESTABLISHED 8592
TCP 127.0.0.1:62706 127.0.0.1:32400 ESTABLISHED 7476
TCP 127.0.0.1:62746 127.0.0.1:32400 ESTABLISHED 7476
TCP 127.0.0.1:62761 127.0.0.1:32400 ESTABLISHED 12280
TCP [::]:32400 [::]:0 LISTENING 8592
All 4 of those PID were Plex services
Well thank you, it seemed to work better this time. It still failed to add about 150 movies, but it is adding them now on a second scan instead of pretending to like it was before. It seems strange to me that Plex’s UI opened from the right click menu of the server application would interfere with the server working correctly. Is this normal or a bug?
system
Closed
August 12, 2020, 2:53pm
9
