Plex not seeing my usb drive on synology 916+
If PMS is running on the Synology, you can use the external drive because it does properly show up in DSM
What you can’t do is share the Synology’s external USB drives to other servers over the LAN.
@Stanl3h said:
Ok sorry again…
I tried creating a new internal partition on the synology the plex could already see but it couldnt see that and on top of that it wont play any of the original content it just gets a spinning golden circle or just flat out crashes now.
I appreciate your time I am sorry to be taking up so much of it.
Not sure what you did. Do you mean you created a new share?
Can you grab the log files please so I can see what PMS can’t handle and attach the ZIP file ?
Of course, I mean I created a new share on the synology main raid array that the PMS can normally see fine to see if it could see it but no luck.
Here is the zip now. By the way as soon as I have the cash I am getting plex premium if we get this sorted, the customer service here is excellent !
I am just going to go make a coffee, I will be back in two minutes while you look at that. Seriously I have said it before mate, but thank you.
Your database has slowed again. It’s causing everything which is trying to play to stop. You have a lot of music, all very properly organized, don’t you?
If true, we will need to tune the default Synology configuration if you’re comfortable with copy/paste of a command line on the Synology shell. If not, we’ll change your Library settings.
Jan 05, 2018 01:23:55.759 [3948] WARN - [Notify] Received unexpected inotify event: 8192
Jan 05, 2018 01:25:41.554 [12803] WARN - SLOW QUERY: It took 250.000000 ms to retrieve 75 items.
Jan 05, 2018 01:54:00.077 [16250] ERROR - XML: namespace
Jan 05, 2018 01:54:00.077 [16250] ERROR - XML: error :
Jan 05, 2018 01:54:00.077 [16250] ERROR - XML: xmlns:ms: ' urn:microsoft-com:wmc-1-0' is not a valid URI
Jan 05, 2018 01:54:00.077 [16250] ERROR - XML:   xmlns:ms=" urn:microsoft-com:wmc-1-0"
Jan 05, 2018 01:54:00.077 [16250] ERROR - XML:                                        ^
Jan 05, 2018 02:01:40.303 [17145] INFO - It's been 7168824 seconds, so we're starting scheduled library update for section 6 (1080p Movies)
Jan 05, 2018 02:01:40.303 [17145] INFO - It's been 7050041 seconds, so we're starting scheduled library update for section 11 (4K Movies)
Jan 05, 2018 02:01:40.311 [17145] INFO - It's been 1582211 seconds, so we're starting scheduled library update for section 13 (4K TV Shows)
Jan 05, 2018 02:01:40.311 [17145] INFO - It's been 602818 seconds, so we're starting scheduled library update for section 12 (Music)
Jan 05, 2018 02:01:40.311 [17145] INFO - It's been 7168689 seconds, so we're starting scheduled library update for section 10 (Temp Movies)
Jan 05, 2018 02:01:40.311 [17145] INFO - It's been 7168773 seconds, so we're starting scheduled library update for section 7 (TV Shows)
Jan 05, 2018 02:01:40.897 [17154] WARN - SLOW QUERY: It took 420.000000 ms to retrieve 75 items.
Jan 05, 2018 02:01:46.133 [17246] WARN - SLOW QUERY: It took 330.000000 ms to retrieve 75 items.
Jan 05, 2018 02:01:49.636 [17248] WARN - SLOW QUERY: It took 270.000000 ms to retrieve 75 items.
Jan 05, 2018 02:01:52.186 [17241] WARN - SLOW QUERY: It took 310.000000 ms to retrieve 75 items.
Jan 05, 2018 02:03:09.349 [17246] WARN - SLOW QUERY: It took 330.000000 ms to retrieve 75 items.
Jan 05, 2018 02:03:11.934 [17241] WARN - SLOW QUERY: It took 270.000000 ms to retrieve 75 items.
Jan 05, 2018 02:03:34.591 [17246] WARN - SLOW QUERY: It took 360.000000 ms to retrieve 75 items.
Jan 05, 2018 02:20:09.035 [19388] ERROR - XML: namespace
Jan 05, 2018 02:20:09.035 [19388] ERROR - XML: error :
Jan 05, 2018 02:20:09.035 [19388] ERROR - XML: xmlns:ms: ' urn:microsoft-com:wmc-1-0' is not a valid URI
Jan 05, 2018 02:20:09.035 [19388] ERROR - XML:   xmlns:ms=" urn:microsoft-com:wmc-1-0"
Jan 05, 2018 02:20:09.035 [19388] ERROR - XML:                                        ^
Jan 05, 2018 02:20:25.165 [3437] WARN - Timed out waiting for server to finish.
Jan 05, 2018 02:20:25.226 [3891] ERROR - Network Service: Error in advertiser handle read: 125 (Operati
Please Optimize the database again and restart PMS to get that back in order.
As for not seeing the share, are you certain user plex has R/W permission to that share? DSM is very sensitive about clicking ‘OK’ after making permission changes
I will be offline for the night now. I am east coast US.
Yeah my music is poorly organised to be fairly its a decade worth of collecting and the program I had used before plex just automatically organised via artist. For now I can remove the music until I find a better way of organising it.
I am UK its 6am here almost been up all night but I don’t dare sleep even if I have a slight migraine or it will wake up 10 times worse.
I am going to try creating a PMS on the synology, I will get back to you. In the mean time I will also remove the music from the plex on the shield to see if that helps.
Well I ended up having to reinstall the plex software on my shield, it just crashed, wouldnt stream anything. I still can’t get the PMS on the shield to see the usb drive on the synology however the PMS installed on the synology seems to be able to handle anything I throw at it including streaming 4k video so I may just end up using that instead of the shield.
Thanks again for all your help last night, can we leave this open just incase anyone else has any great ideas ?
