Plex not seeing Season 3 of Brady Bunch
Hello
So Im adding Brady Bunch to plex for my wife and Season 1,2 and 4 are showing up with no problem. But when I went to add Season 3 plex does not see it. This is how the 1st show looks like as far as how I have the file labeled.
The Brady Bunch - S03,E01 - Ghost Town, U.S.A…mkv
The Brady Bunch - S03,E02 - Grand Canyon or Bust.mkv
Any help would be great…
Thank You very Much…
The Brady Bunch - S03E01 - Ghost Town, U.S.A…mkv
The Brady Bunch - S03E02 - Grand Canyon or Bust.mkv
Get rid of that comma in the S03,E01
For reference: https://support.plex.tv/articles/naming-and-organizing-your-tv-show-files/
Hello
Thank you for your idea… But all my other shows and season 1,2 and 4 of brady bunch went in just fine with the comma. but I did try your idea and plex still did not see the files.
Thank you
Rename the entire show per Plex naming requirements.
Then Plex Dance the entire show.
PowerRename in Microsoft Power Toys can help you rename the files.
For example, rename all S02, to S02 or ,E to E.
Hello FordGuy61
I tried what you said and did the Plex Dance and it WORKED!!!..
Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You, Thank You,
I hope you don’t get mad but I left the comma in my file naming and Plex read it right away…
Again thank you very, very much!!!
