Plex not using Quicksync
Server Version#: 1.24.4.5081
Player Version#: Doesnt use hw transcoding on any player.
Hello guys, I have the problem that plex is not using intel quicksync on my debian 11 stable server. Yesterday I made sure and read many post containing fixes for this. I still have the problem. I choosed one my Media’s as example for not transcoding, but it happens on all types when it needs to transcode.
Plex Media Server Logs_2021-10-13_13-31-42.zip (4.0 MB)
Hardware:
CPU: Intel Core i5-2520M (Sandy bridge) (quicksync supported)
https://ark.intel.com/content/www/us/en/ark/products/52229/intel-core-i5-2520m-processor-3m-cache-up-to-3-20-ghz.html
(I also have Nvidia NVS 4200 gpu, but dont bother with it, im not gonna use it. I just want to use quicksync.)
Software:
Debian 11 stable with kernel 5.10.0-9-amd64
Plex Server Version: 1.24.4.5081 (Yes I have plex pass)
Media File Type:
I created a short file sample
https://www.mediafire.com/file/5rw6q4svdounmop/samplefile.zip/file
Media
(Subtitles off)
  • Duration 1:08:05
  • Bitrate 20253 kbps
  • Width 3840
  • Height 2160
  • Aspect Ratio 1.78
  • Video Resolution 4K
  • Container MKV
  • Video Frame Rate 24p
  • Audio Profile lc
  • Video Profile main 10
Part
  • Duration 1:08:05
  • File Westworld S1E1.mkv
  • Size 9.52 GB
  • Audio Profile lc
  • Container MKV
  • Codec HEVC
  • Bitrate 15673 kbps
  • Bit Depth 10
  • Chroma Subsampling 4:2:0
  • Coded Height 2160
  • Coded Width 3840
  • Color Primaries bt2020
  • Color Range tv
  • Color Space bt2020nc
  • Color Trc smpte2084
  • Frame Rate 23.976 fps
  • Height 2160
  • Level 5.1
  • Profile main 10
  • Ref Frames 1
  • Width 3840
  • Display Title 4K (HEVC Main 10 HDR)
  • Extended Display Title 4K (HEVC Main 10 HDR)
  • Codec TRUEHD
  • Channels 8
  • Bitrate 3671 kbps
  • Language English
  • Language Tag en
  • Audio Channel Layout 7.1
  • Bit Depth 24
  • Sampling Rate 48000 Hz
  • Display Title English (TRUEHD 7.1)
  • Extended Display Title English (TRUEHD 7.1)
  • Codec AC3
  • Channels 6
  • Bitrate 448 kbps
  • Language English
  • Language Tag en
  • Audio Channel Layout 5.1(side)
  • Display Title English (AC3 5.1)
  • Extended Display Title English (AC3 5.1)
Troubleshooting:
Hardware transcoding is on
vainfo
lsmod | grep i915
ls -la /dev/dri
grep render /etc/group
grep video /etc/group
Untitled
apt install ocl-icd-libopencl1 beignet-opencl-icd
I dont understand what’s the problem? Is it because my cpu doesnt support it? Or do I have to install something/configure? I dont use an hdmi dummy plug.
Thank you all very much!
The SandyBridge class machines do not support HEVC.
You minimally need a SkyLake class machine to decode HEVC SDR or a KabyLake class machine to decode HEVC SDR
Oct 13, 2021 12:48:30.325 [0x7fb7d146cb38] DEBUG - [Transcode] MDE: Selected protocol dash; container: mp4
Oct 13, 2021 12:48:30.325 [0x7fb7d146cb38] DEBUG - [Transcode] MDE: analyzing media item 2693
Oct 13, 2021 12:48:30.326 [0x7fb7d146cb38] DEBUG - [Transcode] MDE: E1 - Das Original: Direct Play is disabled
Oct 13, 2021 12:48:30.326 [0x7fb7d146cb38] DEBUG - [Transcode] MDE: E1 - Das Original: media must be transcoded in order to use the dash protocol
Oct 13, 2021 12:48:30.326 [0x7fb7d146cb38] DEBUG - [Transcode] MDE: E1 - Das Original: no direct play video profile exists for http/mkv/hevc
Oct 13, 2021 12:48:30.326 [0x7fb7d146cb38] DEBUG - [Transcode] MDE: E1 - Das Original: no direct play video profile exists for http/mkv/hevc/truehd
Oct 13, 2021 12:48:30.326 [0x7fb7d146cb38] DEBUG - [Transcode] MDE: E1 - Das Original: no direct play video profile exists for http/mkv/hevc/ac3
Thank you Chuck.
Errata in my previous:
SkyLake = HEVC SDR
KabyLake = HEVC HDR
