Server Version#: 1.40.2.8395
I am attempting to access Plex using my domain and Kemp load balancer as the load balancer. However, when I try to access it via my SSL-enabled domain, Plex gets stuck on the login screen. Can you help me with this issue?
Do you have the server’s DEBUG logs ZIP file which captures this?
Plex Media Server Logs_2024-04-22_03-48-51.zip (446.7 KB)
Let me know if you need something else.
Thanks for the logs.
I found it .
Your certificate was not accepted by PMS (which loads when PMS starts)
Cerficates cannot be self-signed certificates.
P12 files must contain the your CRT and KEY, plus the CA (from the issuer)
Apr 22, 2024 01:46:34.113 [139996737366840] ERROR - [CERT] Found a user-provided certificate, but couldn't install it.
Apr 22, 2024 01:46:34.113 [139996737366840] WARN - [CERT] MyPlex: Invalid connection URL 'plex.chroniclefonzie.com'.
While you’re making changes, Given your LAN is IPv4, you can turn off IPv6 support in Settings - Server - Network. Mixing modes complicates TLS use.
Could you walk me thought how to setup it properly? I have a wildcard certs from CloudFlare? I’m using via Kemp LoadMaster and loadBalencing it to my local servers.
First, Your Loadmaster / balancer are for you to resolve manage.
Using certs an advanced topic and should already be known to you.
This is how I generate my P12. The ACME cert is managed by my pfSense.
#!/bin/sh
# Get current cert & key
scp admin@pfsense:/conf/acme/MYDOMAIN.TLD-production.key ./MYDOMAIN.TLD-production.key
scp admin@pfsense:/conf/acme/MYDOMAIN.TLD-production.crt ./MYDOMAIN.TLD-production.crt
openssl pkcs12 -export -out MYDOMAIN.TLD.p12 -inkey MYDOMAIN.TLD-production.key -in MYDOMAIN.TLD-production.crt -certfile "Acmecert_+O=Let's+Encrypt,+CN=R3,+C=US.crt"
