Plex Notify
You are awesome.
Thank you
I was able to select plex server, but it does not save it, every time I close the plex notify the plex server disapeared.
ty
ty
That's OK it's just De selected. Plex Notify can monitor multiple Plex media servers
Sent from my SM-N900P using Tapatalk
you are right, but I noticed the new update has no ip address tracker option.
ty
ty
Yeah its just enabled by default now. Before you needed the log file, now it has it in the API
I had to clean my PC so I am installing PN from scratch. Downloaded V99 ( the log actually shows 100?) and added my user/pwd. Connected to plex ok. Nothing in the Combobox so I can't add my server! I tried to add using 'add' button, that did nothing useful. pressed 'remove' and the app crashed.
Log enclosed shows two errors. I guess the first is because I had no ProgramData. The second seems to be an issue with the DB schema.
Any ideas?
Any ideas?
Yeah looks like on initial setup of the db I still am inserting the default server using the old schema. The configuration error is OK it's expected .
Just add the server in setup it should work fine. I'll fix the default server bug.
Alpha v0.0.0.101
 - Fixed default server not populating.
 - Fixed the main window being over sized on smaller resolution screens. The window will now scale down.
Thanks. That did the trick.
small issue, for PushAlot notifications, I'm trying to disable both client connected and disconnect but it doesn't keep the settings... (when I go back in, it's stuck back enabled)
K just edit the confi directy til i can get another fix out.
1. I tried doing it in config file but still pushes those
2. did the last update included this fix?
Not a big deal though  :)
@sfnetwork:
Possibly something went wrong with the latest update, so you haven’t gotten that one yet.
It’s been several hours since JBurlison announced v0.0.0.101 in his latest post above, and it still hasn’t arrived here, though my PlexNotify has auto-update enabled (and has auto-updated well for several months now, up to and including v0.0.0.100)
Best regards: dlanor
@sfnetwork:
Possibly something went wrong with the latest update, so you haven't gotten that one yet.
It's been several hours since JBurlison announced v0.0.0.101 in his latest post above, and it still hasn't arrived here, though my PlexNotify has auto-update enabled (and has auto-updated well for several months now, up to and including v0.0.0.100)
Yeah same here, didn't update to 101
Seriously I just wanna say what a great add on this is. I share my server with lots of people and its just perfect for knowing when they aren't using it and Im safe to reboot for windows updates etc...
Also I just wanna add that Its refreshing to get support and fixes for any issues straight away. When the WP8 app is launched I'm straight on it!! :)
You are doing a great job with this, thank you so much! I am so excited for many of the features you have talked about.
Any update on when twitter will be added to the notifications? I have some other users who are really waiting for that  :P
Keep up the good work and I will for sure be in line for the IOS app!
I just want to say thanks for such a great utility to use with our plex servers! This app absolutely rocks! I just had a question though...after it updated to 0.0.0.100 I am getting these weird notifications...
Now out of all my users I am the only one with a Nexus 5 but I don't use plex through my Android...so I don't know what this is about. When I look at the Plex Activity log it does not show anyone connected or watching anything. But Plex Notify will show me these notifications.
Go to http://plexip:port/clients/ and see if there's anything in the media container that's where I get the clients from.
Thank you all for the immense support for Plex Notify. You guys are great alpha testers. The community has been fantastic with the bug reports and suggestions. I Plex Notify is getting better and better thanks to you. I hope to make it a must have for Plex Media Server owners.
Has anyone noticed it collecting statistics is getting slow?
Perhaps it is the size of my media library (~10TB) or the amount of people I have it shared to (~100)?
Wow I have never tested it with that kind of volume. There is an option in the settings to keep the statistics cached so you don't have to wait every time.
Yeah, I have a fairly large database and group of people as well. I had to clear the database recently because it was taking WAY too long to load. Seems okay for a month or so, but the statistics database gets soo huge that it takes 10+ minutes to load  :wacko:
I would recommend looking into MySQL. The default database mssqlce is not fast. It's just portable so people don't have to worry about creating a database. If you have this kind of volume the only thing that is going to help the loading speed is a ssd/raid and a real database engine.
Parsing the data takes about 4-7 milliseconds per record with a i7.
