Plex Notify
I know, I have been following the thread but I was still wondering...
So used to see jburlison post frequently that I was starting to get worried lol.
I'll be patient now :)
Not exactly, WPF is way more robust. http://stackoverflow.com/questions/944608/wpf-vs-silverlight
Great app, but WPF is dead.
Any chance of this coming to Mac?
Is it? Roadmap update dated November 12 2014.
From article:
Work on improving WPF has never really stopped, and below are just a few examples of what you should expect to see in upcoming releases of Visual Studio 2015 and .NET 4.6.
Some examples of recent fixes in WPF which will be available in .NET Framework 4.6:
  • Multi-image cursor file support in System.Windows.Input.Cursor
  • Support for transparent child windows.
  • Improved double tap gesture recognition by using common threshold distance from registry.
  • Improved text selection through double tapping the WPF TextBox control.
  • Improved reliability of stylus input for the WPF ComboBox control.
Can this keep track of multiple pms ?
yes. i have movies on one computer at my work and tv shows on a different computer at my house and plex notify running on a third computer. For me it works really good when people start something but a couple moments later it tells me they stopped when they haven't
Subscribed to this thread - I'm excited for its potential!
I looked at plexWatch + PlexWatch Web, but I don't want to install httpd/php services on my server. I'd rather have an all-in-one application with a friendly GUI, which is what you are striving for. keep it up!
Great. Thanks for replying. So my pms lives on a Mac. I wanted to use this but since it doesn't work for Mac I'll install it on windows machine. Is my logic sound here?
yes that is how i have it set up. again it works great when they start something, it just falls apart because it notifys you they stopped when they didn't, but I'm ok until they come out with the new version
In your case I would just turn off the notification for when they stop. I don't use that notification anyway. I just usually want to see if a stream started.
Thanks for you confirmation.
No WPF is not dead... I develop WPF applications for a living.  I could see why you are confused because HTML 5 gets so much love... But no, there will always be a need for a robust, flexible, UI development environment.  And WPF is just that.
If WPF were dead, Microsoft wouldn't have just pushed an entirely rebuilt development suite written in WPF (Visual Studio 2015), which tons of new improvements for developing applications using WPF.
I installed the alpha build and it looks really neat. Looking forward to the beta.
Couple questions though:
Would it be possible to implement pushing to a Channel in the Pushbullet API?
Any way to create/build a custom RSS feed for users to subscribe to for notifications, rather than using specific push apps like growl/pushbullet/etc.?
I know this thread isn't being monitored for bugs/change requests but I just wanted to ask if anybody else is experiencing CPU leakage with the current build. My install seems to be eating between 15% - 25% in idle mode with nothing playing in Plex!
Yes there have been memory and cpu leak issues previously. It seems to have died down for most users as of a few updates back, but there are still some issues that come and go.
Is anyone else having problems with Plex Notify and PMS 9.11.13? My notify just goes into loop now saying it can't connect to either of my servers.
This code development semm to be dead.  No updates from jay in 1 month, which is too bad because this app had real promise and was worth spending the dollars on.
He does go dark every once in a while, but it is a bad sign.
I can't get the web server working, all i have is a blank screen.
Any ideas?
Any ideas?
It doesn't work - known issue.
Sent from my iPhone using Tapatalk
