Plex on Linux Mint
Anyone using Linux to run Plex? I installed it from the software manager but it does not open.
See Linux Mint - Plex Server 1.43.0.10492 Core Dump on Start - #4 by ChuckPa
Bad Idea™, get a different distro.
Which one, any suggestions?
If this is not your regular PC, Ubuntu Server is probably the way to go (do not use Snaps).
l have a hard drive with Ubuntu LTS 24.04.2 that I’d installed and Plex loaded easily. Would you say this OS is a good choice? Oh, and thanks for the tip!
Yes, its a stable and established Plex supported OS.
