Server Version#: 4.1.32
Player Version#: ROKU
So I had OMV 4 and Plex running just fine on my old AMD X2 4200+ machine, but I moved around some files and accidently wiped my Plex database. I tried to reinstall, with no luck, so I decided just to reinstall OMV. I still can’t get Plex to start. After 6 reinstalls (4 x v4, and a v5 for giggles). I’m the furthest I’ve gotten so far though with the current 4 install. This is an old machine with 2GB RAM, so I went with the Plugin instead of Docker. Everything else is working great, but when I try to enable Plex and choose a directory it throws this error:
<< Failed to execute command ‘export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; systemctl start ‘plexmediaserver’ 2>&1’ with exit code ‘1’: Job for plexmediaserver.service failed because of unavailable resources or another system error. See “systemctl status plexmediaserver.service” and “journalctl -xe” for details. >>
and viewing details give this:
<< 1. Error #0:
2. OMV\ExecException: Failed to execute command ‘export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; systemctl start ‘plexmediaserver’ 2>&1’ with exit code ‘1’: Job for plexmediaserver.service failed because of unavailable resources or another system error.
3. See “systemctl status plexmediaserver.service” and “journalctl -xe” for details. in /usr/share/php/openmediavault/system/process.inc:182
4. Stack trace:
5. #0 /usr/share/php/openmediavault/system/systemctl.inc(86): OMV\System\Process->execute(Array, 1)
6. #1 /usr/share/php/openmediavault/system/systemctl.inc(104): OMV\System\SystemCtl->exec(‘start’, NULL, false)
7. #2 /usr/share/openmediavault/engined/module/plexmediaserver.inc(46): OMV\System\SystemCtl->enable(true)
8. #3 /usr/share/openmediavault/engined/rpc/config.inc(194): OMVModulePlexMediaServer->startService()
9. #4 [internal function]: OMVRpcServiceConfig->applyChanges(Array, Array)
10. #5 /usr/share/php/openmediavault/rpc/serviceabstract.inc(123): call_user_func_array(Array, Array)
11. #6 /usr/share/php/openmediavault/rpc/serviceabstract.inc(149): OMV\Rpc\ServiceAbstract->callMethod(‘applyChanges’, Array, Array)
12. #7 /usr/share/php/openmediavault/rpc/serviceabstract.inc(565): OMV\Rpc\ServiceAbstract->OMV\Rpc{closure}(’/tmp/bgstatus2R…’, ‘/tmp/bgoutputmH…’)
13. #8 /usr/share/php/openmediavault/rpc/serviceabstract.inc(159): OMV\Rpc\ServiceAbstract->execBgProc(Object(Closure))
14. #9 /usr/share/openmediavault/engined/rpc/config.inc(213): OMV\Rpc\ServiceAbstract->callMethodBg(‘applyChanges’, Array, Array)
15. #10 [internal function]: OMVRpcServiceConfig->applyChangesBg(Array, Array)
16. #11 /usr/share/php/openmediavault/rpc/serviceabstract.inc(123): call_user_func_array(Array, Array)
17. #12 /usr/share/php/openmediavault/rpc/rpc.inc(86): OMV\Rpc\ServiceAbstract->callMethod(‘applyChangesBg’, Array, Array)
18. #13 /usr/sbin/omv-engined(537): OMV\Rpc\Rpc::call(‘Config’, ‘applyChangesBg’, Array, Array, 1)
19. #14 {main} >>
I’m kinda at a loss. There wasn’t anything different in my install than there was in my original install that worked. I really don’t know what to do. I had it working perfectly and now this. I’m debating whether or not to try another install of OMV 4 (I tried 5 also in a earlier install and it didn’t work) or go with something else.
I find it all strange because when I installed OMV 4 and Plex months ago on this old machine it was super easy. I’m not sure what’s wrong at this point and could use some help. While my Mac & Win skills are strong, my Debian skills aren’t as sharp. I can provide whatever info and logs needed. Thanks in advance.
