Plex on QuTS
Please see PM. You may post your logs & Info there securely.
Thank you very much for your support here :slight_smile:
I’ve installed 2x1Tb NVME SSD for QTS and PMS, and migrating my media files from Synology to the new QNAP Raid 6.
quick question: do you keep the “tmp_transcoding” directory in the NVME SSDs, or in the raid 6? I would stay in SSDs to speed up the process (needed?), and if the storage space should be an issue I would limit the number of movies that can be transcoded simultaneously (300Gb should be enough?)
thanks again
Andrea
I keep it on the RAID 6.
Reason:
  • RAID 6, even if it was slow and giving you only 300 MB/sec,
  • 300 MB/sec translates to 2400 Mbps of streaming per second
Conclusion:
  • RAID 6 is more than fast enough. No need to wear out your SSD prematurely
    – Make a shared folder on the HDDs for “PlexTranscoding”
    – Point the transcoder temp directory there.
    – Keep it off your SSDs
