Hi all,
shall I install PMS on QuTS, or do I need to stay with QTS?
thanks
Andrea
Hi all,
thanks
Andrea
Last we looked, QuTS is slower.
At the filesystem level, itās far more obfuscated because QNAPās naming convention doesnāt use shared folder names; they use numbers.
If you want things ācleanā and faster (ZFS isnāt fast), QTS is where you want to be.
the big advantage of ZFS (as far as I understand) is the quicker way to swap a faulty hdd on raid pool. Features like compression or deduplication shouldnāt be a must for multimedia server. Perhaps more useful for virtual machines (but this is another story)
That may be true of a normal ZFS installation ā but this is QNAP. They put their own twist on ZFS.
We were disappointed when we saw it. It had such promise.
Their implementation for VMs is the same on both QuTS/QTS; a third-party VM engine.
Video files donāt compress
Replacing a drive is a Reboot on both OSās.
You can continue to use it while itās rebuilding
QTS is faster (the disk i/o is faster)
Consider we are talking about a TVS-h874-i5-32G with x Seagate Exos X20.
Most of the files are media files (Music, Movies, Photos, ā¦), so not to be compressed.
Documents and VMs perhaps can take advantage of compression and deduplication, but if you say this is a ācrazyā deployment of ZFS (nothing to compare to TrueNAS, just on top of my mind), perhaps better to stay on EXT4.
My biggest concern (even if, I know, itās a bit crazy, I know) is āwhat happens if during the raid rebuild something wrong happensā, like another hdd dies, or stuff like that. Iām implementing RAID 6, so Murphy should look me right in the eye, but ā¦
Still suggesting QTS, right?
edit: another point for QTS is the possibility to add online a new hdd to the pool. That should give me the possibility to start with 6 hdd instead of 8
I agree with you: Stay on QTS as itās nothing to compare against TrueNAS.
EXT4 will serve you well.
I WISH they offered XFS. XFS is far better suited to ābig dataā we have now.
EXT4 volumed > 50TB are considered āless than optimal/safeā.
Sure, it will work but you should take the extra precautions of a good UPS dedicated to the NAS as these things need 10-15 minutes to shut down.
Re: Adding HDD to the pool.
If speed and space are your thing ā Use a Static Volume.
ā Grabs the whole drive at creation
ā Leaves the āpoolā layer out of the storage stack.
Yes, you can
ā add HDD on the fly to the volume
ā grow the FS to use the full volume size
Recommend: As you create the volume, Look for the āAdvancedā settings.
ā For media use, youāll want to make the inode size 65536. (there will still be plenty of inodes left over for small files)
I have a TVS-1282-i7-64GB w/ 8x 8TB WD Red Pro (7200 RPM)
The drives are a static volume with 65536 inode size.
RAID 5 configuration only because this is my backup server. The main is RAID 6
Hereās the performance of raw read at the outer cylinders of the drives (peak performance)
[~] # dd if=/dev/mapper/cachedev2 of=/dev/null bs=2M count=80000
80000+0 records in
80000+0 records out
167772160000 bytes (156.3GB) copied, 142.587852 seconds, 1.1GB/s
The machine has 10GbE connected and it does a good job of reliably pushing 750-800 MB/sec NFS to my workstation.
Here is the main config. Notice DataVol4 is a pool (where I experiment)
DataVol1 = 2x 500GB SATA-3 SSD (mobo)
DataVol2 = 8x 8TB WD Red Pro
DataVol3 = 1x 500GB SATA-3 SSD (Plex metadata use)
DataVol4 = 1x 256 2.5" HDD (play space)
So you suggest to donāt use the entire space as a single volume (even if static)? with 6 20tb disks Iāll have around 54Tb. So better to stay below 50Tb?
Another thing. My NAS can have n.2 M.2 PCIe Gen 4, what about put two small SSD disks in raid 1 to manage the plex metadata? As caching in general canāt be helpful for me, but this solution should be good for PLex, right?
Andrea
Iām sorry if that sounded wrong. Iām having some difficulty writing today.
The TVS-1282 has 14 slots: (2 are internal)
Hereās my active configuration:
2x 500 GB SATA-3 on mobo
ā QTS is installed here (CACHEDEV1).
ā Created as a static mirror volume.
ā * This allows me to boot QTS without ANY hard drives installed. This is really beneficial when performing initial setup and maintenance.
8x 8 TB HDD in slots
ā Media is stored here (CACHEDEV2).
ā Created as a static RAID volume using all 8 drives (inode size = 65536)
1x 500 GB Samsung SSD in 2.5" slot 1
ā This is where I installed Plex (and its metadata).
ā Created as a single static JBOD (525 MB/sec speed is fast enough for my work)
1x 256 GB WD Laptop HDD in 2.5" slot 2
ā I āmess aroundā on that drive. I use it for development and testing. There isnāt anything of value on it.
My approach is based on not wanting to tear the box apart every couple years because I burned out an SSD from all my Plex work. I am very hard on equipment.
With UPS in place and attached to the NAS ![]()
Use your 20TB drives as you intend (growing to 8x 20TB) RAID 6 ![]()
ā Create the volume as a Static volume, RAID 6 on 6 drives initially,
ā When the RAID is ready, Format it with inode size 65536
ā Later, add drive(s) as you are ready.
You will be RAID 6 - Thatās a huge amount of protection. ![]()
Donāt worry about my ā50TB warningā PROVIDED you have a UPS attached to it. The problem with EXT4 is that the chains get long as volume size grows. With good UPS and RAID 6, you donāt have to worry.
Resultant space
ā 20 TB - 9.05% = 18.19 TiB
ā 8 drives - 2 parity = 6 Data drives
ā 18.19 * 6 = 109.14 TiB static volume before formatting
ā Formatting will use about 5% with inode size=65536
ā Approx 103.6 TiB (decimal TB is larger)
Put a NVME SSD (1 or 2) on the Mobo first and install QTS there
ā RAID 1 (Mirror) if you use two NVMe drives
ā STATIC volume
ā No special formatting (QTS has more small files than big files) options.
ā 512 GB is plenty unless you also want PMS there. (I would use 1TB SSDs)
After QTS is installed and on the NVMe drives,
ā Install the HDDs
ā Create your initial RAID 6 - 6 drive - static volume
ā Format with inode size=65536
Go have fun. PMS can stay on your SSDs
You can add a QNAP QM2-2P-384 NVMe carrier card if you want to get Plex off your system SSDs.
fantastic answer, thank you very much ![]()
Now itās crystal clear
thank you
Iāve another issue now to be managed, but itās quite different. I have 3.2Tb of PlexMediaServer directory, and 3.1 is in /tmp (it seems I have a lot of āmusic-analysis-inputā folder, I have a large Music library and I was trying to ānormalizeā the volume with the loudness feature ⦠Iāve removed all the thumbnails, but Iāve recovered only 300 Mb)
Any suggestion?
Sorry to bother you also with this ![]()
Thanks anyway for your recommendations on NAS configuration, much appreciated
Andrea
The stuff in /tmp is PMS not cleaning up after itself ![]()
The answer for it is
lol
Before you do anything, can you show me where/how youāre computing the size of 3.2 TB ? (did you go into the shell?)
just checked the properties of āAppDataā folder via DSM 7. Consider few months ago Iāve migrated from DSM 6 to 7. Value: 3.19Tb
with du -s the value is different: 3421172284
du -s in AppData/tmp: 3409571184
ls: 0038e076051815c2d6a440ba4a2fa06e.jpg006de2b67f5c6db546032bff721b14c6.jpg00 - Pastebin.com
shall I remove everything there?
Yes, delete the JPG files from AppData/tmp
( A bit of a curve ball here. Talking QNAP and then slipping in a Syno ā haha)
ahah right ![]()
shall I remove also the āmusic-analysis-inputā folders?
well, actually Iāve disabled the sonic analysis feature (I donāt use predominantly plexamp), and also the loudness analysis feature (Iāve tagged my music with ReplayGain, it should be enough).
So I think I can remove it
Yep⦠go for it.
do you think it should be possible to put the PlexMediaServer folder in the SSD, but move the /tmp into another pool? If I take 1Tb SSD for QTS and PMS, I suspect this feature will full the space very quickly.
It seems this feature is not designed correctly, imho
what do you think?
Thanks anyway for everything @ChuckPa ⦠you helped me a lot ![]()
Andrea
are we talking about DSM or QTS ?
If youāre talking about the JPEG files, etc, thatās not design issue ā thatās a bad bug
talking about what I see in DSM ⦠and trying to avoid in QTS.
I think this feature:
https://support.plex.tv/articles/sonic-analysis-music/
needs to be implemented better. I have a big Music collection (700Gb), but this canāt create 3.2Tb extra files because of a feature, whatever feature it should be.
Does it make any sense? Do you have the possibility to raise the issue internally?
Thanks again
Andrea
If youāll grab the PMS DEBUG logs (ZIP file),
attach it here,
Iāll raise a new issue or attach to existing.
If you have anything which still shows what itās doing to your system, please also link here in your next post.
Iāll collect it all up and use together
Shall I post my logs here? is that secure?
