I understand Plex on Sonos requires NAT loopback to be enabled on router. Unfortunately, my router doesn’t support it (well, it does, but I’d have to disable Cut through forwarding (CTF) which limits my speed to like 250Mbps down from 1Gbps).
If I use Plex’s Relay feature (where you can access your Plex library outside your home even if your router blocks incoming connections), will Plex on Sonos work even without NAT forwarding?
My Sonos and Plex servers are on the same home network.
