This is my 2nd post about this problem, I had thought other software was causing my crashing but I have turned that off and my problem keeps happening.
Synology Server Version#: DSM 6.2.3-25426 update 3
This screen shot is to show what happens after plex stops.
All I do to start the software is click run.
this has happened a few time in the last few days.
Plex Server Version#: 1.22.1.4228-724c56e62-x86_64_DSM6
Player Version#: 4.29.6
Hardware: Plex Media Player / Windows 10
Player Version#: 1.30.0.2105-43a11204
Hardware: Plex for Windows / Windows 10
Player Version#: 4.53.0
Hardware: pc/Chrome
Player Version#: 8.14.1.2.23548 - android version#:4.9.125
Hardware: sony x9500h
Player Version#: 8.14.1.23548
Hardware: samsunt tab2
Hardware: samsung s8+
For android, which is the main reason to crash, go get the beta (either 8.15 or 8.16 – not sure current beta version)
For PMS, upgrade to 1.22.2.4264 - Another issue was fixed there with the hubs (also a reason to crash) . This is the more likely solution because your logs show the hub being accessed just before it crashed.
Mar 31, 2021 23:23:22.394 [0x7f3c08e31700] DEBUG - HubCache: Adding '1/home.continue/1/hubs/promoted/en-nzexternal-media,indirect-media/contentDirectoryID=9&count=10&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=summary%2Ctagline%2Cfile&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&libraryHubsOnly=1' to the cache (1/home.continue/1/hubs/promoted/en-nzexternal-media,indirect-media/contentDirectoryID=9&count=10&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=summary%2Ctagline%2Cfile&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&libraryHubsOnly=1).
Mar 31, 2021 23:23:22.394 [0x7f3c08e31700] DEBUG - HubCache: Adding '1/home.ondeck/1/hubs/promoted/en-nzexternal-media,indirect-media/contentDirectoryID=9&count=10&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=summary%2Ctagline%2Cfile&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&libraryHubsOnly=1' to the cache (1/home.ondeck/1/hubs/promoted/en-nzexternal-media,indirect-media/contentDirectoryID=9&count=10&excludeElements=Actor%2CCollection%2CCountry%2CDirector%2CGenre%2CLabel%2CMood%2CPart%2CProducer%2CRole%2CSimilar%2CWriter%2CPhoto%2CVast%2CTopic&excludeFields=summary%2Ctagline%2Cfile&includeExternalMetadata=1&includeLibraryPlaylists=1&includeMeta=1&includeRecentChannels=1&includeStations=1&includeTypeFirst=1&libraryHubsOnly=1).
Mar 31, 2021 23:23:22.787 [0x7f3c4e20e700] WARN - Crash: Crash reporting disabled
Mar 31, 2021 23:23:22.797 [0x7f3c099e9700] DEBUG - It took 200.000000 ms to retrieve 10 items.
--- end-of-file ---
You can enter/leave beta access in the Google Play store.
Go to the Plex app in the Google Play store on your device (not on the web page). Scroll down. You should see the option to enter/leave beta access between the Developer Contact and About this app sections.
I do not know if beta access is immediate. I signed up using the old method.
Curious - are we saying that a bad version on the device could kill PMS? Just making sure. I literally had a new device get added and it didn’t even occur to me that this could happen.
Read the thread I linked (read to the bottom of the thread). You can ignore those messages.
Plex is picking up announcements from other devices on the network - cameras, etc. If the announcements are in a format Plex does not understand it will create an entry in the Plex log files.
When you see a device constantly advertising via SSDP, something isn’t right with the equipment.
I have my equipment, TVs, and Onkyo on the same LAN.
None of them stream SSDP availability (which PMS will respond to).
PMS will ping them once each cycle (30 seconds) to confirm it’s still available.
